Commander wear - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 05-04-2014, 10:52 PM Thread Starter
rick's Avatar
Commander wear
Thought I would just comment on the Commanders IIs longevity. The Bridgestones that came on my bike when new aren't even in the same league as these. I started looking for the Commanders by the time I had 5000 miles on the bike because I knew they werent going to last much longer, Ended up changing the rear at 6300 miles. I now have 5100 miles on the rear and checked the tread with depth guage today and still have 7/32 of tread left. I believe they have 8/32 new, so if they continue to wear at this rate, I figure I should easily get around 25,000 miles from this tire. I dont ride it too hard, it is a touring bike after all, not a canyon carver, but I ride it the same as I did the stock tires.
2005 800 classic
2012 Voyager ABS
rick is offline
post #2 of 6 (permalink) Old 05-05-2014, 12:04 AM
BOTM Winner, April 2014
Steammaker's Avatar
I'm glad to hear they're working out for you. I didnt have a good experience with the Commander II's. Developed a front end wobble that I was only able to fix by replacing the tire. I only got 6000 miles on them before they were removed. I had high hopes for the too...
'03 MEANSTREAK
Steammaker is offline
post #3 of 6 (permalink) Old 05-05-2014, 08:03 AM Thread Starter
rick's Avatar
I just put on the front tire, only have about 1,400 miles on it, but sofar, so good
2005 800 classic
2012 Voyager ABS
rick is offline
post #4 of 6 (permalink) Old 05-05-2014, 02:59 PM
griffjo's Avatar
Is that a 140/90-16 rear tire on that 800 Classic?
If so, a new COMMANDER II rear tire's tread depth is ~8mm (~10/32"). If you're down to 7/32", it's about 1/3 shot. Based upon this, it looks like you may get around 15,000 or more miles from that rear tire.
It's no 25,000 miles, but it's still a good bit better than the 6,300 you got from that OEM Bridgestone. Mine has over 10,000 miles and looks to be wearing as well, or perhaps even a little better. I rationally expect to get 18,000 from the rear tire and 24,000 from the front tire.
I have yet to find a better tire than the Michelin COMMANDER II. Like any tire, someone will have a less that perfect experience with it [no one is perfect, so every manufacturer will produce its share of lemons], but, for the most part, almost everyone who has gotten one has been pleased.
GRIFFJO
Montani Semper Liberi
2003 Vulcan® 800 Classic - Pearl Mystic Black
National Cycle Custom Heavy-Duty Windshield
Mustang Two-Piece Wide Vintage Touring Saddle
Volar SissyBar/Backrest - K&N Air Filter
Viking Quarter Circle SaddleBags & SissyBar Bag
Scootworks Sprockets (18/40 - 2.222:1 ratio)
Baron 3" Bullet Tachometer - Engine Guard (black gloss finish)
Michelin COMMANDER II front 130/90-16 73H, rear 140/90-16 77H
EK X-Ring Chain, Deer Warning Whistles & BackOFF® Brake Module
griffjo is offline
post #5 of 6 (permalink) Old 05-05-2014, 11:00 PM Thread Starter
rick's Avatar
Its a 180/65/16 on my Voyager. Wasnt sure about new depth, guess I confused 8mm with 8/32s. Still should be much better than the stock. The 800 still has the 880s I put on it last year. If I didnt have the Voyager, I'm sure they would be shot by now, at least the rear.
2005 800 classic
2012 Voyager ABS
rick is offline
post #6 of 6 (permalink) Old 07-05-2014, 03:41 PM
R_W_B's Avatar
I hear the Michelin Touring Commander II comes in a radial or bias. Which ones did you guys get. Do you like one over the other, pros/cons? ( I realize you need to run the same on the front and the rear)
R_W_B is offline
Weird Noises and tire wear Dadinator Wheels and Tires 22 04-12-2010 08:02 PM
Tire wear ....info supercub Vulcan 900 1 07-04-2009 06:33 PM
tire wear... :) Pixie General Vulcan Talk 5 07-04-2009 04:14 PM
Anyone wear a kidney belt? bigmoe General Vulcan Talk 0 04-05-2009 08:02 PM
Eye wear question Hollywood98 General Vulcan Talk 9 02-26-2009 10:16 AM
