Tire Pressure: Can't believe my Owner's Manual - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 04-01-2014, 10:11 PM Thread Starter
When I bought my 2005 Vulcan 800 Classic two years ago, there were no manuals, so of course the forums have been my source of education. Well, I just down-loaded a manual from Kawasaki and note that they specify tire pressures of 28 psi front and rear, unless riding two-up in which case rear should be 32 psi. Wow. My mechanic recommends 40 psi front and rear. The motorcycle cop instructors at the intermediate riding class I attended recommend whatever the maximum is on the sidewall, which on mine are either 40 or 44 (forget, I have to go look). Their concern is that when you have an emergency, handling is more important than a nice comfy ride.
I've ridden with lower tire pressure, somewhere just under 28, and didn't like the lessened responsiveness to the steering.
So I don't think I can agree with the manual on tire pressure. So my question is, what else is likely to be incorrect in the manual? Or is the manual actually right?
Red 2005 Vulcan Classic 800
National Cycle shield
River Road saddlebags
Patriot Guard Rider
SummitJim is offline
post #2 of 11 (permalink) Old 04-01-2014, 10:19 PM Thread Starter
This reminds me of my truck and my other mechanic. Door jam sticker says 28 psi for the truck, my mechanic always sets it to 40. Sidewalls say the maximum is 44 psi. I once asked the mechanic about this difference and the answer was "it's a truck, you haul stuff in it. Want a soft ride, drive your wife's Honda." Made sense to me.
Patriot Guard Rider
post #3 of 11 (permalink) Old 04-01-2014, 10:33 PM
V2K Rogue Wrangler
Kaw-poke's Avatar
Tires wear faster at lower pressures because they flex more and that extra flex generates more heat. If you like the ride at 40 psi then you will probably get more miles out of your tires than the guys who go for the softer ride at lower pressures. Or not. Who knows!
Oh, I run both front and rear at 40 psi butt I'm double Darkside so I'm crazy.
Sent from Motorcycle.com App
Kaw-poke is offline
post #4 of 11 (permalink) Old 04-01-2014, 10:51 PM
Roadie's Avatar
38 psi front and 44 psi rear in the Commander IIs on my 2011 Vaquero, ride, handle, and wear great.
Roadie
2011 Vaquero
Amsoil Oil | TLC Bag Liners
Mini Beast Air Horn | Sagebrush Bag Chaps
Power Commander V | Cobra Tri-Oval SlipOns
Thunder Tornado Air Kit | Madcorider Oil Tempstick
Marvellas Trailer Hitch Kit | Rumbling Pride Flag Mounts
Utopia Drivers Backrest | Sagebrush Leather Tank Bib
Michelin Commander II Tires | Classic's Engine/Road Bar Chaps
Wind Vest 10" Smoked Windscreen | Avon Grips with RacNRay's Throttle Mod
4 Wheels Move the Body & 2 Wheels Move the Soul
Roadie is offline
post #5 of 11 (permalink) Old 04-01-2014, 10:57 PM
40 will get ya great mpg with a harsh ride as the tires won't give. All the cushion is left to the shocks. Less than 30 will give a soft pleasant ride at the expense of mpg and handling. Your handling goes do to sidewwall flex forcing the tire to scrub the road versus gripping it. The scrubbing also adds to your tire wear. Meaning replacement more often.
I run mine at 32 same as my car. I'm not a dare devil and therefore don't nead the extra grip, and the extra dollar spent on fuel is well worth the soft comforable ride.
It's a personal preference you have to make but there's no added danger by running lower or higher. You either want handling and mpg. Or cruising comfort. 32 to 35 seems like the happy medium to me.
Kawboysix is offline
post #6 of 11 (permalink) Old 04-01-2014, 11:31 PM Thread Starter
Thumbs up
Kowboysix, like your thinking. I'm a pretty conservative rider, not into pushing the envelope. Maybe I ought to try varying the pressure and paying close attention to the ride and handling and find my own best setting. My previous bike had a decidedly mushy feel to the steering with the lower pressures, but can't truthfully say about the Vulcan. Hey, another reason to ride!
I do tend to listen carefully to the guys who spend 8 hours a day every day riding, but then they have to be ready for high performance riding more than I do.
Patriot Guard Rider
post #7 of 11 (permalink) Old 04-01-2014, 11:33 PM
Bear2123's Avatar
I run my '05, 800B at the 28 & 32 without issue. Mileage is around 48mpg, handling is fine and braking / turning is no issue. Your option. Remember that those are cold temps. Pressures will increase as the tire temps go up...
In God I Trust, all others, Bring Data!
Bear2123 is offline
post #8 of 11 (permalink) Old 04-02-2014, 04:22 AM
GeorgiaRider's Avatar
I ran my tire pressures on my Vulcan 500 near the recommended 28/32 for years (if I remember correctly). I run Metzler ME-880 tires now and they recommend higher pressures. I run 32-34 on the front and 35-36 on the rear now. If I run the tires much higher than that it's too rough of a ride for me.
GeorgiaRider
2006 Vulcan 500
Saddlemen Cruis'n Large Slant Saddlebags
Kuryakyan Foot Peg Extenders and Pegs
Kuryakyan Iso-Grips and Throttle Boss
Memphis Shades Alley Cat Windshield
Powersports Mini-Tachometer
Kawasaki Luggage Rack
Airhawk cushion
Marlin's Clock
GeorgiaRider is offline
post #9 of 11 (permalink) Old 04-02-2014, 04:52 AM
Fawlty's Avatar
Same here on my 1991 500. I run at 28/32, which are the workshop and owners manual recommended pressures. I find them the most comfortable pressures.
"It begins here for me on this road. How the whole mess happened I don't know, but I know it couldn't happen again in a million years."
(Johnny Strabbler-The Wild One 1953)
Kawasaki Vulcan EN500A2, 1991 (California Spec.)
Fawlty is offline
post #10 of 11 (permalink) Old 04-02-2014, 05:57 AM
well, I didnt think it much mattered, but after 2 days of riding with 42#'s I could definitely use a softer ride. Maybe i'll give 36-38 (a happy medium) a try.. ;-)
Captcoolhand is offline
Still can't believe it...Bought my first bike a 900 Custom SE ! JetBlack6 Vulcan 900 40 01-01-2016 01:10 AM
Can you believe it? TB2000 Vulcan 2000 14 09-29-2012 07:49 AM
because they CAN, they believe they MUST Poncho Villa The Lounge (Off Topic) 21 09-13-2012 03:52 PM
Can't believe the difference! marcwhite Vulcan 900 2 08-08-2012 12:36 PM
Can't believe I'm asking this..... Coach Joe Community Help 15 08-26-2010 10:03 AM
