Trying my luck on this section here - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 18 (permalink) Old 06-11-2019, 06:32 PM Thread Starter
Charbie92's Avatar
I recently came into possession of a 2007 vulcan 900 custom. After my first long ride i get back home and before shutting it down, the electronics all cut out and just running lights stay on. after parking it in the garage i try restarting it and there is nothing at all. I looked and it blew both the ECU and the IGN fuses. I inspected the wiring for shorts and found none, i replaced the battery thinking that was the issue. After replacing the fuses and trying again, the ecu fuse blows as soon as i turn the key, the IGN fuse blows as soon as i turn the killswitch to on. My neighbor said that the bike fell over in his garage and caused a little damage, i was wondering if the position sensor could be causing the wires to short if it was laid down or if it resets after being set back up? im at a complete loss at this point.
I can fix airplanes, but at a complete loss on motorcycles.
Charbie92 is offline
post #2 of 18 (permalink) Old 06-12-2019, 09:40 AM
1. How many miles on it?
2. Describe exactly what you did just before the fuses blew.
3. Any modifications...fuel processor, lights, etc?
sfair is offline
post #3 of 18 (permalink) Old 06-12-2019, 10:40 AM Thread Starter
Charbie92's Avatar
It has just over 22000 miles on it, i was on my first longer ride just over 100 miles. When i pulled onto my street the electrical system flickered and only the sidelights stayed on but it was choking and sputtering as i pulled into my driveway. I turned everything off and turned it back on and tried cranking it again. It cranked for a second then blew a fuse. I inspected the wiring and didnt find any shorts or broken wires. I replaced the ECU and the IGN fuses. When i turned the key to the bike to on it immediately blew the ecu fuse, once i turned the killswitch to run it blew the IGN fuse.
post #4 of 18 (permalink) Old 06-12-2019, 11:53 AM
Vulcan guy's Avatar
Year/Make/Model: 2001 Vulcan VN1500, 2005 Vulcan VN1500
Displacement/CC's: 1500
Color: Green, Blue
I would doubt if it's the position sensor. More likely inclined to believe harness going to run switch got pinched/damaged somewhere in the fall, or even the switch itself. That's where I'd start looking.
Vulcan guy is offline
post #5 of 18 (permalink) Old 06-12-2019, 02:28 PM
1. Question #3?
2. Do you have a meter and know how to use it?
No meter, we can help there too.
Do not just start poking around for fear of losing the issue or adding another. Then the real tail chasing begins.
sfair is offline
post #6 of 18 (permalink) Old 06-12-2019, 03:06 PM Thread Starter
Charbie92's Avatar
Yeah, i have just a cheap multimeter of my own. But i have a nicer one at work i can use if i need it.
post #7 of 18 (permalink) Old 06-12-2019, 03:43 PM
Could you post the make and model # of the meter that you choose to use for my reference.
sfair is offline
post #8 of 18 (permalink) Old 06-12-2019, 03:47 PM
Question #3?
sfair is offline
post #9 of 18 (permalink) Old 06-12-2019, 07:35 PM Thread Starter
Charbie92's Avatar
Im sorry for the delay, i won't be back home for a few days for medical reasons then i can update you.
post #10 of 18 (permalink) Old 06-12-2019, 08:16 PM
No problem. Take your time.
sfair is offline
