Rear tire locked up when shifting from1st to 2nd. - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 04-23-2019, 09:56 PM Thread Starter
I have a 2004 Vulcan 900 classic. It won't go into neutral but the neutral light comes on, when I let out on the clutch it's in gear, and when I take off from 1st and go into 2nd it locks up the back tire. I have to rock the bike to get it unstuck. I push the bike about 10 feet and the back tire locked up again . I don't have a clue what is going on. Any help would be greatly appreciated! Thanks
Dw69 is offline
post #2 of 2 (permalink) Old 05-14-2019, 12:18 PM
bigblockyeti's Avatar
Year/Make/Model: 2008 V2KLT
The neutral light will only illuminate when the neutral position cam on the shift drum depresses the switch so if it's going on and off, the shift drum is moving. It sounds like you may have a bent shift fork just enough to allow it into multiple gears at the same time which will allow only a little rear tire rotation before binding things up to the point it can lock the tire. Has it been shifted hard from 1st to 2nd many times (or one time really bad)?
bigblockyeti is offline
150/80-16 Rear Tire Question griffjo Vulcan 800 17 08-15-2017 07:54 AM
Lowered VN800B rear tire rubbing jfl1960 Vulcan 800 10 05-16-2016 06:48 PM
Rear wheel removal Serenity Rider Vulcan 1700 6 06-01-2015 04:44 PM
Darkside shepsvoyager Vulcan 1700 33 08-14-2013 02:05 AM
