Gas in oil - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By Patrick's1500
post #1 of 7 (permalink) Old 01-06-2019, 08:37 AM Thread Starter
Leephus09's Avatar
Gas in oil
Yeah so I got a 2018 Vulcans se abs, two months ago I changed the oil on my bike, and my collection pan reaked of gas so bad that I had to remove it from my shop. I took it in to the dealer and they told me that it was normal for small amount of gas to get in with the oil. So i contacted the factory about it and they had me take it back to the dealer, where the techs are gonna talk and go over it with factory support. I got it back and they told that the factory said that it was an acceptable amount of gas in the with the oil. Does anyone else have a similar problem, or does anyone have any thoughts on this? Please let me know, because I'm just not quite buying that it's acceptable.
Leephus09 is offline
post #2 of 7 (permalink) Old 01-06-2019, 10:05 AM
Year/Make/Model: 2007 VN900 Custom (heavily modded)
Displacement/CC's: 900
Color: plasma blue
No, gas in the oil is not normal in the least, something is seriously wrong with your bike. I'd recommend taking it to a different dealer as those guys you first went to are idiots.
GrahamM is offline
post #3 of 7 (permalink) Old 01-06-2019, 09:48 PM
Patrick's1500's Avatar
Year/Make/Model: 2004 VN 1500E7
Displacement/CC's: 1470
Color: green over white
I have to concur with Graham. Gas Oil gets in oil in two primary ways- through worn/defective piston rings or defective injectors that don't close. In either event, gas in the oil is not "normal," most especially in a brand new bike, and acts as a solvent to thin the oil.
As a for instance, my bike is almost 15 years old, 45+k miles, and I have never had the smell of gas in my oil.
bearslayer likes this.
Patrick's1500 is offline
post #4 of 7 (permalink) Old 08-10-2019, 08:10 AM
Considering that oil is present in the cylinder when there is ignition, there is going to be trace amounts of fuel in the oil. More so if your running rich. The strength of smell weighs on a number of variables, ranging from using conventional oil, long intervals between oil changes, not seating you piston rings after break in, etc.
Though I encourage trying another dealership and see if you have a different response. I recently had an individual tell me that I should (only) change my rear sprocket... some places hire family (even if unqualified) I reckon.
Nitwit is offline
post #5 of 7 (permalink) Old 08-10-2019, 09:12 AM
whoaru99's Avatar
How many miles on the bike?
Had it been thoroughly warmed up on your previous drives before the change or maybe was it mostly shorter drives?
Do you occasionally, or maybe frequently, start it just to hear/see it run without actually driving it...or just a quick trip around the block, so to speak?
whoaru99 is online now
post #6 of 7 (permalink) Old 08-10-2019, 03:07 PM
Check the plugs for fuel/carbon fouling.
If they pass, then do a fuel pressure retention test, key off.
sfair is offline
post #7 of 7 (permalink) Old 08-13-2019, 10:55 PM
See “Emission Control Information” (1. & 2.) in the Owners Manual it provides a possible explanation imo
Nitwit is offline
Gas in my Oil/Gas in the Crankcase vscoy00 Vulcan 1500 10 09-14-2014 10:31 AM
Yellow Gas light, still have gas. CptCrusty1 Vulcan 1600 10 07-29-2013 10:41 AM
Gas smell from gas cap jp58 Vulcan 1700 7 03-26-2012 10:34 PM
to much gas in gas tank !!! ???? cuba1 Vulcan 500 18 08-11-2011 09:05 AM
Gas Cap Whistle and Gas Smell rboyle21 Vulcan 2000 16 06-06-2011 08:53 PM
