Carb removal on 98 VN1500 - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 03-22-2014, 11:47 AM Thread Starter
Hi folks-
New to riding and mechanicing. Need to pull the carb on my VN1500 classic. I'm a bit stuck. What's the preferred way to loosen the throttle cables to pull the carb? I've been using a couple manuals but they seem a little vague. Also been searching for a good video to illustrate the carb removal process, but with little luck so far. Any suggestions?
Ponyboy is offline
post #2 of 4 (permalink) Old 03-25-2014, 09:22 AM
PatC's Avatar
It can be a bear, but I just fiddled with mine until they came off. The enricher cable screws out, the one set of cables attach with a screw on the side and then a ball and slot. Did you remove the gas tank? That helps.
04 1500 Classic
Mustang Seat
Sissy bar, luggage rack,
light bar, 2" risers,
Isogrips, Fatbar crashbars,
offset hiway pegs, tank bib,
passenger floorboards,
new brake pedal, throttle lock,
Cobra Lowboy Shotgun pipes,
Baron's Big Air relocated right side,
tombstone tail light,forkbag,
detachable hard leather bags,
alarm, power port, clock,
and a cool cupholder
PatC is offline
post #3 of 4 (permalink) Old 03-25-2014, 11:36 AM
Living The Dream
DeputyLoud's Avatar
http://www.vroc.org/faq/carb/carb-howto.html
Found this link in the 1500 forum by doing a search for the word carb. Might help?
Loving My Mid-Life Crisis!
2008 Vulcan 900 Classic LT
1991 Harley Electra Glide Classic FLHTC
DeputyLoud is offline
post #4 of 4 (permalink) Old 11-07-2017, 11:57 PM
Originally Posted by Ponyboy View Post
Hi folks-
Hi. I am having the exact same problem. I can't figure out how to remove the throttle cables from the carb. I have the service manuals, have asked several friends who work on bikes and searched all over the internet. I can't find anything to help.
Have you found out or have you any answers to your problem?
Sure could use some help.
Jim
OldJim is offline
98 vulcan vn1500 no start Guido570 Vulcan 1500 96 04-15-2018 12:05 PM
Replacing the POG 98 vn1500 dabs Vulcan 1500 4 02-25-2016 03:32 PM
Changing my "98 VN1500 from stock to rock bobber_the_chopper Vulcan 1500 5 06-27-2013 06:50 PM
Does anyone know the fender widths on a 98 VN1500 Classic? Bigpetem20 Vulcan 1500 9 09-17-2012 12:57 PM
'98 VN1500 Running hot keithstanley Vulcan 1500 14 05-25-2010 09:05 AM
