Clutch problems - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 05-15-2019, 03:39 PM Thread Starter
travisthebiker's Avatar
Year/Make/Model: 01 Kawasaki Vulcan 1500 Nomad
Displacement/CC's: 1500
Color: Blue
Clutch problems
So my clutch is messing up on me. I have ZERO clutch travel. It actually tries to pull forward while its clutched. I bought the bike off my father in law and he said he had brand new clutch plates put in it and he had the same problem and it turned out that (I think) the reservoir has a pin hole that got clogged and he had a guy just clean it out and it fixed it. Has anyone else had this problem?
Sent from my SM-G965U using Tapatalk
travisthebiker is offline
post #2 of 9 (permalink) Old 05-15-2019, 04:07 PM
VN750Guy**'s Avatar
Year/Make/Model: 2006
Displacement/CC's: 750
Color: Red/black
I'm not familiar with the 1500's. Is there an adjustment knob/wheel/thingy on your clutch handle on the handlebar?
Chris Cochran
Retired USAF '74 to '95 AMMO
Engine guard with highway pegs
Luggage rack
GPS on RAM handlebar mount
MCCTs replaced ACCTs
Iridium plugs: DPR7EIX-9
Custom made seat (verrry comfortable)
LED turn signals with rear signals relocated
LED license plate holder
Hard mounted Viking saddlebags
Hard mounted fork tool bag (free from Viking)
LED running lights on custom light bar
National Cycles Low Boy Heavy Duty windshield
Home made lowers
Last edited by VN750Guy**; 05-15-2019 at 04:08 PM. Reason: I put a "space" where I didn't want it.
VN750Guy** is offline
post #3 of 9 (permalink) Old 05-15-2019, 07:30 PM Thread Starter
Color: Blue
No it's all hydraulic.
post #4 of 9 (permalink) Old 05-15-2019, 09:12 PM
Tanner1500's Avatar
It’s dose happen sometimes and something will clog the tiny hole and cause the clutch not to work properly. Another thing I have ran into is getting air in the line. When I had my 1500 nomad I replace the clutch in it and forgot to bleed the system my clutch would not engage it would not work properly until I bled the hydraulic line of all the air.
Tanner1500 is offline
post #5 of 9 (permalink) Old 05-15-2019, 10:26 PM Thread Starter
Color: Blue
Originally Posted by Tanner1500 View Post
Itís dose happen sometimes and something will clog the tiny hole and cause the clutch not to work properly. Another thing I have ran into is getting air in the line. When I had my 1500 nomad I replace the clutch in it and forgot to bleed the system my clutch would not engage it would not work properly until I bled the hydraulic line of all the air.
Is there a bleeder valve for the clutch?
post #6 of 9 (permalink) Old 05-15-2019, 11:19 PM
Tanner1500's Avatar
If you have a hydraulic clutch then yes it should have one, just follow the line from the clutch down to the motor and at the end of that line will have a bleeder. You might need to pull the side engine cover off to get at it. If your not sure how to bleed the system message me again and I’ll try and give you a step by step on how to do it
post #7 of 9 (permalink) Old 05-16-2019, 03:01 AM Thread Starter
Color: Blue
If you have a hydraulic clutch then yes it should have one, just follow the line from the clutch down to the motor and at the end of that line will have a bleeder. You might need to pull the side engine cover off to get at it. If your not sure how to bleed the system message me again and Iíll try and give you a step by step on how to do it
Thanks man
post #8 of 9 (permalink) Old 05-19-2019, 07:58 AM
SPIKEDONE's Avatar
Are you sure that the right "Shim" plates were installed i had this problem when i tried to do my clutch bike was still pulling even with clutch pulled in they sell different thickness of 1 plate that acts as a shim
SPIKEDONE is offline
post #9 of 9 (permalink) Old 05-22-2019, 04:01 PM Thread Starter
Color: Blue
I have no idea man. A shop around town did it.
hydraulic clutch bleeding cruiserron Vulcan 1500 4 06-02-2014 04:17 PM
Thought I was having clutch problems Matt140 Vulcan 500 6 04-19-2014 02:16 PM
Clutch grimness!!! simonveasey Vulcan 1500 3 09-01-2012 09:35 AM
clutch problems Rogertherk Vulcan 1500 0 06-01-2011 12:26 PM
clutch problems mooneman Engine Work 10 07-24-2008 05:23 PM
