'01 1500 Classic FI - Cam Chain Tensioners?! - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
post #1 of 39 (permalink) Old 02-13-2019, 02:40 PM Thread Starter
stupidName's Avatar
Year/Make/Model: 2001 VN1500 Classic FI
Displacement/CC's: 1470
Color: red
Exclamation '01 1500 Classic FI - Cam Chain Tensioners?!
So I pulled the cap off the rear cam chain tensioner to see if I could tell if it's fully outstretched. I've attached a couple pics. My question is, to what part of the body am I supposed to be "measuring" to determine their position?
I found this site talking about the checking and replacing:
https://www.vulcandrifterriders.com/camtensionext.html
And in it: "When the cap/springs/etc. are removed, the extender rod will be somewhere in the following range:
At full retraction, the rod end will stick above the end of the threaded body by +0.342"
At full extension, the rod end will sink into the body by -0.356" Note the rod shown in the picture at left is down 'inside' the threaded body by a quarter inch. With only about 1/16" left it's time for replacement."
And the picture it refers to looks very similar to mine, and that is probably my answer.... BUT....
I'm somewhat confused by the phrase "the rod end will stick above the end of the threaded body by +0.342""
It seems to me there isn't enough room under the cap for that to be the case! Or, maybe as my name implies, I'm just being stupid!
I'd appreciate some input from someone who's done this before and knows from first-hand experience. I'm hopeful that my suspicions are correct because this would fix the gawdawful noise! But I don't want to do it if I don't have to, know what I mean?
ID:	226912   Click image for larger version
2001 Kawasaki VN1500 Classic FI
(purchased 2/8/19)
1992 Yamaha XV1100
(purchased 2010)
stupidName is offline
post #2 of 39 (permalink) Old 02-13-2019, 06:40 PM
Denny606's Avatar
Year/Make/Model: 07 900 Classic ,O5 1500 Classic
Displacement/CC's: 900, 1500
Color: Red... Black
If it goes down inside the housing that's threaded it needs extenders.
"When all is said and done there's usually more said than done" unknown
"Ride hard or stay home" Joe Robinson AKA Old Dog ,Tater. RIP old friend
Denny606 is offline
post #3 of 39 (permalink) Old 02-14-2019, 11:05 AM Thread Starter
stupidName's Avatar
Color: red
I've ordered extensions... hopefully that'll quiet 'er down a bit!
(purchased 2/8/19)
1992 Yamaha XV1100
(purchased 2010)
post #4 of 39 (permalink) Old 02-16-2019, 04:48 PM Thread Starter
stupidName's Avatar
Color: red
So I got the extenders today. Didn't realize you have to pull the tank and everything between the cylinders to access the front tensioner! Not impressed. But anyway, I put the rear one in and now I can hear a very distinct steady chain noise. I about give up. I guess it is what it is and I'll ride it 'till it blows up. Yay. I shoulda walked away when I heard the thing running.
(purchased 2/8/19)
1992 Yamaha XV1100
(purchased 2010)
post #5 of 39 (permalink) Old 02-17-2019, 11:30 AM Thread Starter
stupidName's Avatar
Color: red
Another question... when I reinstalled the tensioner body, I had a hell of a time getting the bolts started because I had to push really hard against the body, in turn, against the chain guide. The rod was fully retracted. If the tensioner had reached the end of its travel, I would think that reinstalling it with the rod fully retracted with the extender installed, there would only be a minimal amount of force required to install the body to take up the slack in the chain. I did read somewhere that hearing chain noise after installing the extenders is "normal" for the first couple hundred miles... but my trust in peoples' assessment of "normal" concerning these engines is quickly fading.
(purchased 2/8/19)
1992 Yamaha XV1100
(purchased 2010)
post #6 of 39 (permalink) Old 02-18-2019, 07:49 AM
Patrick's1500's Avatar
Year/Make/Model: 2004 VN 1500E7
Color: green over white
These things make a rattly chain nose, because the timing chains are being pushed against by guides. The tensioners press against the guides and keep tension on the chain. This is the rattling. It probably does sound loud to you, but you're sitting on top of the motor and the cam chains are closest to you. I suspect if you were to lift the hood on your car or truck and go sit on top of the engine when it's running you would hear a lot of noises you don't hear inside the cab. My bike made a lot of noise even brand new, so much that I took it back to the dealer with 100 miles on it thinking there was something wrong with it. Nope, it's just the nature of Kaw's overhead cam system in their bigger bore engines.
Changing the cam chain tensioners is a pain, but I had already chopped out the crossover tube between the cylinders and went with an air kit directly bolted to the carb, so all that stuff was out of the way. But I can tell you this: if you're expecting tensioner extenders to give you a quite ride, it isn't going to happen. It will, however, keep your cam chain from skipping a tooth if it gets stretched too far or from rubbing on the spark plug tube and wearing a hole in it.
I've never had a motorcycle that didn't have some innate flaw in the design. Every single one of them had some irritation I had to put up with or try to mitigate. Seems to be the nature of it. All I can say is you just have to decide if the wind in your face is worth all the hassles the bike gives you. Mine has always provided me with far more happiness than misery, so it's all good. If there's a perfect bike, I probably wouldn't like it because it would probably be some perfectly engineered crotch rocket. LOL
Patrick's1500 is offline
post #7 of 39 (permalink) Old 02-18-2019, 03:02 PM
Originally Posted by Patrick's1500 View Post
I've never had a motorcycle that didn't have some innate flaw in the design. Every single one of them had some irritation I had to put up with or try to mitigate..
My experience with a narrow selection of Honda, and Kawasaki bikes that I've owned over the years (except for two-strokes), is that I've never owned one that didn't have some inherent flaw with the cam chain tensioning mechanism. Not sure why it seems to be so difficult to design one that works properly.
VulcanDrifter is offline
post #8 of 39 (permalink) Old 02-18-2019, 09:23 PM
Denny606's Avatar
Color: Red... Black
Thumbs up
Here is the answer to almost everything Vulcan related
Vulcan Gadgets Fixit Page For Kawasaki Nomad & Classic Modification Maintenance & Repair
Look under the new to Vulcans page especially number 5
Denny606 is offline
post #9 of 39 (permalink) Old 02-19-2019, 07:21 AM
Yes. I recall when I was a kid, right after the moon landing my parents always saying "well, gee, if they can put a man on the moon, how come they can't....." and fill in your own blank. One would think they could come up with a minimally stretching cam chain but I guess not. Then again, they probably make several hundred million revolutions in their lifetime under intense heat at rapid speed, so there is that. Maybe we should be amazed at how long they last!
post #10 of 39 (permalink) Old 02-19-2019, 08:38 AM Thread Starter
stupidName's Avatar
Color: red
Thanks for the input guys. This is my third twin. The first one I had was an '97 Suzuki Intruder 800. I was young and dumb and don't remember any glaringly out of place engine noise... except for when it exploded inside and blew a hole out the side of the crankcase and locked the back tire at 80 mph after riding it across the country! Fast forward 20(ish) years and here we are. I currently own both of my other two twins.
My Virago 1100 made an ungodly clickety clackety when I first got it until I did a well-beyond-schedule valve adjustment which quieted it down to a very normal sounding ticking to go along with all the normal clunking and whirring of a twin (especially air-cooled)... until it began to develop a low end knock.
I'm very aware of the fact that I sit directly above the engine and can hear every internal noise. I was also an ASE Certified auto mechanic for several years... so I understand the internals of engines.
The Vulcan's knock (which I know is not sticky lifters or cam chain noise) is just simply not something that I see as remotely normal. Sorta. I'm trying to convince myself that it is. The biggest reason why is this: after another attempt at locating the source of the knock with a screw driver, I believe it is coming from the left lower case... in FRONT of where the crankshaft is located. I believe that's the location of the left "balancer". I've also read many instances of people tearing into their engines and finding evidence of these balancers being worn, replacing them, to no affect.
So yes, maybe this knock is normal. I can only HOPE that it is, and monitor it closely as I begin to put some miles on this beautiful beast, because quite frankly, the only alternative (in my mind) is a main crank bearing. It fits the symptoms exactly... other than the "location", which of course my method of locating is inherently inaccurate.
But back to the cam chain tensioners! I think I'm gonna bite the bullet and pull the tank to add the front extender. I plan to run the tank as low as possible on the road then run it dry in my driveway before pulling it to reduce spillage as much as possible.
(purchased 2/8/19)
1992 Yamaha XV1100
(purchased 2010)
1500 Namad Wheel on a 1500 Classic? DubsVulcan Vulcan 1500 27 02-11-2018 09:36 AM
How about cam chain tensioner extensions? windbreaker Vulcan 1700 1 02-07-2014 04:33 PM
1500 classic exhuast on a 1600 classic pittdave Vulcan 1600 1 11-20-2012 12:28 AM
Cam Chain Replacement Beelzebub Vulcan 500 3 08-06-2012 05:59 AM
Compared 1500 Classic vs 1500 Mean Streak? Mad Kaw Vulcan 1500 3 04-30-2009 09:18 AM
