Turn Signals are Out - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 09-26-2018, 04:29 PM Thread Starter
Year/Make/Model: '06 VN750, '95 VN1500
Just picked up a '95 88 for a bagger project. Mostly good shape, signals are out though, among a few other things. Front running lights still work, but nothing on all four turn signals and no signal light on the dash. PO was trying to convince me it was just the dash lightbulb that was out; haven't tried that but I’m not convinced. Fuse looked good. Relay out maybe? Any help would be greatly appreciated!
LandyLou is offline
post #2 of 9 (permalink) Old 10-04-2018, 06:42 AM Thread Starter
Any advice out there?
LandyLou is offline
post #3 of 9 (permalink) Old 10-04-2018, 06:57 AM
Color: Black / grey
Since no lights blink try the flasher?
vulcandoc is offline
post #4 of 9 (permalink) Old 10-04-2018, 07:00 AM Thread Starter
As in the hazard lights? Interesting idea, hadn’t tried that yet. Is that a different control unit that the signals?
LandyLou is offline
post #5 of 9 (permalink) Old 10-04-2018, 10:12 AM
Color: Black / grey
No I'm saying since no signals work as they should I would check that the box that controls this is checked.
Since its an older bike you should just have a signal flasher box - I guess about $10 or less.
Or connection s to the box.
post #6 of 9 (permalink) Old 10-11-2018, 12:07 AM Thread Starter
Thanks for the advice! Sorry for the slow reply, been out of town for work. I’ll start cleaning connections at the switch. Any idea how to locate the signal relay? I’ve been having trouble locating the right wiring diagram, but even if I found it, I don’t know if it would be all that helpful in locating the actual relay on the bike...
LandyLou is offline
post #7 of 9 (permalink) Old 10-11-2018, 07:04 AM
Color: Black / grey
Sorry, it could be the switch, but I'm suggesting the flasher, what you are calling the relay.
If all four of the signals dont work then it makes sense the part that makes them "blink" is the most likely,
as well as the connection to this as well.
It will most likely be under the seat by the battery. A small rectangle about 1.5" to 2" in size.
post #8 of 9 (permalink) Old 10-11-2018, 09:13 AM Thread Starter
Thanks, Doc I think we’re talking about the same thing. “Signal relay” was my best guess at a part name. Is “Flasher” the real name?
LandyLou is offline
post #9 of 9 (permalink) Old 10-17-2018, 09:23 AM Thread Starter
So I found the flasher: it was unplugged! Plugged that baby in and got most of the functionality back. Left signal only worked intermittently, so I ordered a new flasher in the mail. Got it yesterday, took 30 seconds to install, and Voila!
I’ve still got an issue with the front left blinker, but the dash light and rear left are looking much better.
Thanks for all the help!
LandyLou is offline
Retrofit LED Lamps for Existing Turn Signals- Turn Signals 101 rangemaster728 Vulcan 650 S 32 02-03-2018 04:12 PM
Rear Turn Signal Problem - Old Signals Work - Replacement Signals Don't merc Vulcan 500 9 06-17-2015 10:01 PM
Turn off self-cancelling turn signals? LordRahl007 Vulcan 1600 20 07-28-2014 11:19 AM
Changing rear turn signals to run-brake-turn Blue Vulcan 900 5 04-01-2013 11:07 AM
Rear Turn Signal Connection Aftermarket Turn Signals dccatfan General Vulcan Talk 7 03-18-2012 05:04 PM
