Cell phone charger help - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 15 (permalink) Old 09-10-2017, 08:49 PM Thread Starter
TrainingWheels's Avatar
Year/Make/Model: 2007 Kawasaki Vulcan 1500
Displacement/CC's: 1500
Color: Blue/Black
I picked up a cheap USB cell phone charger from walmart.com. I thought I could connect it to the electrical auxilary connections under the tank, alas that did not work..
The unit I'm trying to connect has a 10 amp inline fuse. Acesori connections are 12 volt and 5 volt.
I read an another Forum that this has been done connecting such a device into the headlamp bucket. I thought I should ask here before attempting that.
Sent from my SM-G935V using Tapatalk
TrainingWheels is offline
post #2 of 15 (permalink) Old 09-10-2017, 11:43 PM
texasnurse's Avatar
Year/Make/Model: (SOLD) Kawasaki Vulcan S [Harley-Davidson FLXTRS Road Glide Special]
Displacement/CC's: 107 (1746cc)
Color: Bonneville Salt Pearl
texasnurse is online now
post #3 of 15 (permalink) Old 09-11-2017, 12:13 AM
Little Bit's Avatar
Year/Make/Model: 07 Vulcan Classic
Displacement/CC's: 1600
Color: Silver
Gender: Female
My previous owner of my Vulcan Classic had a pigtail outlet for heated gear from the batter so my wrench just pugged it in there and of course you need to get the correct wire that charges your particular phone. Hope that helps.
Little Bit is offline
post #4 of 15 (permalink) Old 09-11-2017, 09:55 PM Thread Starter
Color: Blue/Black
The wires under the tank... are they extensions of the battery? Or, are they intended for cell phone chargers and the like?
post #5 of 15 (permalink) Old 09-11-2017, 09:56 PM Thread Starter
Color: Blue/Black
After connecting my elcheapo is doohickey directly to the battery, and getting nothing, I determined it's a dud.
post #6 of 15 (permalink) Old 09-11-2017, 10:20 PM
texasnurse's Avatar
They are only powered with the relay
Get out there and feel the wind in your Helmet! ATGATT
post #7 of 15 (permalink) Old 09-12-2017, 07:14 AM
Color: Black / grey
ANYTHING that uses a USB connection does not draw 10 Amps.
The most is 2 Amps.
And the new USB 3.1 type is just a bit more.
Also the bike is at 12 volts and anything that plugs into USB will be 5 volts.
Your cable/charger needs to reduce the voltage down so you do not blow up your cell.
1995 en500 stock with windshield - 29,000 miles
vulcandoc is offline
post #8 of 15 (permalink) Old 09-12-2017, 09:31 AM
Patrick's1500's Avatar
Year/Make/Model: 2004 VN 1500E7
Displacement/CC's: 1470
Color: green over white
I bought one of those DC cigarette lighter-type charging ports and drilled a hole in my right side cover and mounted it there. I wired it right to the battery with its own relay and fuse. Job done. Works with any car charger.
Patrick's1500 is offline
post #9 of 15 (permalink) Old 09-12-2017, 12:50 PM Thread Starter
Color: Blue/Black
I'm sorry I'm so dense, and testing the patience of people who are more Adept with a wrench than I... I was hoping for something more plug-and-play... However would you explain why I would need a relay? I would like to know what the accessory cables under the tank are for if they are not for cell phone chargers.
post #10 of 15 (permalink) Old 09-12-2017, 01:29 PM
trainermb's Avatar
Year/Make/Model: 2007 Kawasaki Vulcan 900 Classic LT
Displacement/CC's: 900
Color: Black & Silver
The relay is typically for a situation where you wanted to run something that would blow the 10 amp fuse connected to those accessory hook-ups, such as an air compressor. A relay is just an electrically controlled switch. You'd use a low amp circuit to trip the relay that connects the high amp circuit.
For your phone charger, those accessory hook-ups should be fine. As someone mentioned, you're not going to get more than 2 amps through a USB device, unless you want to see the magic smoke that makes it work. I have a USB adapter on my bike that's hooked up ....erm .... somewhere. Maybe. I dunno, the PO did it and it doesn't actually seem to BE hooked up at the moment. One of those things that's on the winter list. But the adapter hangs by the right side of the seat and has a little snap-on weather cover to keep the crud out. Seems like a smart idea. Whatever plug you end up with needs to drop the 12v of the bike down to the 5v of USB, but any car charger would do the trick, and there are also direct connect units if you just want the USB outlet without installing the cigarette lighter style 12v convenience outlet. That convenience outlet is, as many have discovered, one of the worst imaginable designs for a connector on a motorcycle, so unless you need one I can understand choosing to skip it.
I seem to remember some have found that those accessory wires aren't actually hooked up to power, so you might stick a meter on the one you plan to use before you get too far into things. You may need to do a little backtracking of wires and whatnot.
"Don't force it. Get a bigger hammer."
- William Shakespeare
trainermb is offline
Off-topic - Cell phone text bomb advice? WBLScott Vulcan 900 13 04-25-2012 08:46 PM
Cell phone holders: looking at a few and want opinions. BoneJj General Vulcan Talk 4 12-22-2011 11:08 PM
Cell phone while riding wbilotta Vulcan 1700 10 01-25-2011 06:54 AM
Talking on the cell phone while riding? Kerry General Vulcan Talk 17 01-22-2011 11:55 AM
Cell Phone Numbers Go Public next month...... Toddster The Lounge (Off Topic) 3 05-03-2009 05:03 PM
