2003 meanstreak rear cylinder backfilre and misfire - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 06-05-2016, 12:27 PM Thread Starter
Folks:
I have had this bike for about 10 years. It is a 1500 meanstreak. It has a hypercharger, a power commander, and a set of V&H longshots with no baffles. The power commander program is from Thunder Manufacturing in AZ. No changes have been made for about 5 years. Recently it began backfiring loudly. It is typically when I am slowing or coming back to idle. In addition it seems to misfire on the back cylinder at idle. I could use some advice from the group.
msstas1 is offline
post #2 of 10 (permalink) Old 06-05-2016, 03:40 PM
Paulie C's Avatar
Year/Make/Model: 2003 Vulcan Classic
Displacement/CC's: 1500
Color: Black Cherry
I would check the obvious first. Make sure the exhausts flange nuts are tight, and no gasket leaks. They can loosen up and cause popping and backfiring.
Paulie C is offline
post #3 of 10 (permalink) Old 06-18-2016, 05:47 PM Thread Starter
Well as an update I tried several things. First I unhooked the power commander with no change. Then I checked to be sure the ics tubes were still pluged, they are. I switched the injectors with no change. I checked to make certain the exhaust was tight, it is. I pulled the plugs and they are black. I replaced them and the new ones are black after 5 minutes. Air filter is clean and the flapper on the hypercharger is opening properly. I still have no idle, and am getting backfires. I could use some advice from the group.
msstas1 is offline
post #4 of 10 (permalink) Old 06-18-2016, 06:22 PM
1. How many miles on it?
2. Could you post a picture of the plugs?
sfair is offline
post #5 of 10 (permalink) Old 06-18-2016, 07:04 PM Thread Starter
19000 miles
msstas1 is offline
post #6 of 10 (permalink) Old 06-18-2016, 08:33 PM
And that is after 5 minutes?
sfair is offline
post #7 of 10 (permalink) Old 06-18-2016, 08:36 PM Thread Starter
Those are the old ones
msstas1 is offline
post #8 of 10 (permalink) Old 06-18-2016, 08:51 PM
Could you post a picture of the ones currently installed?
sfair is offline
post #9 of 10 (permalink) Old 06-19-2016, 01:36 PM
Year/Make/Model: 2016 Kawasaki Voyager; 2004 VFR800; 2003 VTX 1300
Color: Phantom/Spark
Check your fuel pressure regulator.
"A good long ride can clear your mind, restore your faith, and use up a lot of fuel"
"I believe in treating everyone with respect, but, first you have to get their attention"
Never be ashamed to unlearn an old habit...
gearhead759 is offline
post #10 of 10 (permalink) Old 07-06-2016, 04:39 PM
Year/Make/Model: 2002 Kawasaki Vulcan Mean Streak
This may be a stupid question but have you checked to make sure that your PC is actually functioning properly and is turning on? Mine recently bit the dust and I was getting the same issues. When I tried looking at what map was on it I discovered my PC had actually died. I called DynoJet and they are having me send it back and are sending me a new one at a discounted price.
easyrider1500 is offline
misfire every now and then Kojack Vulcan 800 2 08-25-2012 07:11 PM
2003 Meanstreak starting issues husrddy76 General Vulcan Talk 1 09-26-2011 09:15 PM
vulcan 500 misfire...still rickvulcan Engine Work 3 11-17-2010 04:50 PM
'08 Vulcan 500 misfire rickvulcan Engine Work 2 11-13-2010 10:11 AM
changing the fuel pump on 2003 Meanstreak 1500 Noel Gallagher Vulcan 1600 0 02-27-2010 02:52 PM
