1500 Mean Streak Surging at idle - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 04-14-2014, 05:41 AM Thread Starter
Send a message via Skype™ to Corney
I have a 2002 1500 Mean Streak with about 60K on it. It has a throttle body on it. It also has a hyper charger. The bike ran fine before. It backfires on deceleration but I also do not have the baffles in the mufflers. One came out while driving and the other I took out to get the right size for replacement and have not put it back in yet. The bike would idle fine. The caps on the end of the cam shaft were leaking. So I pulled the motor and changed them. I put the motor back in and now It surges at idle. When I try to adjust the idle it quits. The bike starts fine if you give it a little gas. With the choke on some it will start with no throttle. I did nothing to the throttle body.
Corney is offline
post #2 of 3 (permalink) Old 04-14-2014, 10:14 AM
Take a look at this:
http://www.gadgetjq.com/tb_cleaning.htm
Post back with results.
sfair is offline
post #3 of 3 (permalink) Old 04-16-2014, 07:15 PM Thread Starter
Thumbs up
Sfair I cleaned the throttle body like you suggested. It was not that dirty. It shines now . While cleaning it I noticed a vaccum hose not connected. I took the tank off and found where it went. The bike runs fine now. Thanks for the input I did not know to clean the throttle body.
Corney is offline
Where to find Mean Streak Special Edition decals? "Vulcan, Mean Streak, 1600" and "Ka kissmydrums Vulcan 1600 1 03-18-2015 02:30 AM
surging idle while in gear jjack010 Vulcan 2000 11 12-16-2013 02:24 PM
Picked up a 2008 Mean Streak SE Yesterday! NEED SOME MEAN STREAK OWNER OPINIONS MOLON LABE Vulcan 1600 1 08-06-2013 08:51 AM
Can 06 mean streak wheels fit an 03 mean streak. cuba1808 Wheels and Tires 0 01-18-2012 09:13 AM
