2008 kawasaki mean streak 1600 - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 04-23-2019, 05:27 AM Thread Starter
VN900 BAHRAIN's Avatar
Hi there I have got an issue with my bike and I hope if someone can guide me thru the issue, the above bike is not running smoothly, at the cold engine I have to start it 3 to 4 times until it runs, after it starts running the idle condition is not as it should be, the engine is very static and the rpm is not stable, as it keeps on fluctuating up & down, and while driving the bike is jurking and sometimes black smoke comes out from the exhaust.
I have cleaned up the fuel injections, and the air filter, I have also noticed that some pipes were damaged I replaced all of them, but still the issue is not cured.
Who can help me.... cheers
VN900 BAHRAIN is offline
post #2 of 6 (permalink) Old 04-25-2019, 08:56 AM Thread Starter
Hi there any one can help please
post #3 of 6 (permalink) Old 04-25-2019, 03:23 PM
As an easy first step - I would ensure all ground points are cleaned and making good contact. Next, check all the connections to sensors and the ECU are clean and connectors are properly seated.
VulcanDrifter is offline
post #4 of 6 (permalink) Old 04-25-2019, 04:25 PM Thread Starter
Hi bro
I have done all what you mentioned in advance but yet, the bike running engine still static and it runs bad on idle, I'm getting crazy, even after driving the bike for long time still the problem going on, thought might get smooth at a hot engine.
post #5 of 6 (permalink) Old 04-25-2019, 08:33 PM
sfair is offline
post #6 of 6 (permalink) Old 04-26-2019, 01:22 PM Thread Starter
Thank you for your help and advice will definitely look in to the details
God bless you
