Ecu - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 12 (permalink) Old 11-19-2018, 06:27 PM Thread Starter
bbbusmc's Avatar
Year/Make/Model: 2006 Vulcan Nomad
Displacement/CC's: 1600
Color: Black
Ecu
Anyone ever have their "Brain" shit out on em? I'm thinking mine gave up. 06 1600 Nomad, been running great, went on a decent ride, stopped to get gas, bike had trouble starting. It cranks finally and I get it in the garage. Next afternoon couldn't get it to start, changed fuel pump, plugs, unhooked cobra fi, nothing. Now after all that if I turn the key on it blows the ECU fuse. Anyone?
bbbusmc is offline
post #2 of 12 (permalink) Old 11-19-2018, 08:17 PM
Why did you change fuel pump?
sfair is offline
post #3 of 12 (permalink) Old 11-20-2018, 05:46 AM Thread Starter
bbbusmc's Avatar
Color: Black
Chaged it cause I wasn't seeing, smelling fuel in the carb or coming out the plug holes. Only getting a slight trickle out of the pump when the fuel line was disconnected and I turned the key on.
bbbusmc is offline
post #4 of 12 (permalink) Old 11-20-2018, 07:28 AM
DaPreacha's Avatar
Year/Make/Model: 2012 Kawasaki Nomad
Color: Red/silver
I had an 06 classic that had a bared wire under the seat that would blow the main fuse every time I hit a bump in the road. I had to strip the bike down and follow wires until I found it. Ended up being on a corner going around the battery box to the ECU. Fixed it and put foam on the corner and never had another problem with it.
DaPreacha is offline
post #5 of 12 (permalink) Old 11-20-2018, 09:39 AM
1. ???? Your bike is fuel injected; what do you mean by carb and plug holes?
2. Did you do a fuel pressure and volume check on fuel pump?
3. Was replacement pump OEM?
sfair is offline
post #6 of 12 (permalink) Old 11-20-2018, 11:05 AM Thread Starter
bbbusmc's Avatar
Color: Black
Still has a carb, its why you a choke, and if you take off the air box and open the butterfly you can see gas shoot into it, if you pull the plugs you can look into the hole. No pressure test/ didn't know.
bbbusmc is offline
post #7 of 12 (permalink) Old 11-20-2018, 11:06 AM Thread Starter
bbbusmc's Avatar
Color: Black
And yes pump was OEM replacement
bbbusmc is offline
post #8 of 12 (permalink) Old 11-20-2018, 11:16 AM
OK, something not right here:
1. All 2006 1600 Nomads were FI.
2. How many miles on it?
3. How long have you owned?
4. Was the fuel pump in tank or external
5. You even mention disconnecting Cobre FI.
sfair is offline
post #9 of 12 (permalink) Old 11-20-2018, 11:32 AM Thread Starter
bbbusmc's Avatar
Color: Black
Throttle body instead of carb, if that helps. Had it 7 yrs, pump is in tank, 70,000 miles
bbbusmc is offline
post #10 of 12 (permalink) Old 11-20-2018, 11:33 AM Thread Starter
bbbusmc's Avatar
Color: Black
Disconnect Cobra go to see if it was the issue, thats when ECU fuse started blowing
bbbusmc is offline
Mileage with the new ECU twowheeladdict Vulcan 1700 86 04-22-2011 09:39 PM
Have you had your ECU replaced?comments rrjsandman Vulcan 1700 107 01-31-2011 01:55 AM
Wrong ECU installed for Recall GONRDN Vulcan 1700 2 11-16-2010 09:50 AM
Vulcan 900 Recall ~ECU Problems~ [2009-2010] durox Vulcan 900 3 10-31-2010 09:23 AM
2009 ECU reflash mitchkeller87 Vulcan 900 4 03-06-2010 01:17 PM
