Extra o ring after oil change - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 10-25-2018, 08:29 AM Thread Starter
Year/Make/Model: 2008 kawasaki nomad
Displacement/CC's: 1600
Color: blue/silver
I have a 2008 Nomad 1600.
I changed the oil, the oil filter and drained the oil through the oil screen. I replaced with new filter, and oil and cleaned the oil screen.
So far things are going well. I emptied my oil catch basin into a plastic bottle for disposal and I found an o ring at the bottom of the catch basin. I measured the inside diameter of the o ring and it is pretty close to 35mm.
I checked my oil filler screen cap, and my oil filler cap and both of these have an o ring on them.I can.t figure out where this o ring should go.
Any ideas?
TIA
Tom
chipguy1 is offline
post #2 of 6 (permalink) Old 10-25-2018, 09:24 AM
CRU
CRU's Avatar
Sure it's not the grommet (part #92071) at the end of the screen? Did you drain the oil via the drain plug or the oil screen?
https://gadgetsfixitpage.com/article...can-oil-screen
2008 Mean Streak Candy Fire Red
Vance & Hines Big Shots Staggered exhaust
Dyno tuned Power Commander III & K&N air filter
Corbin Young Guns saddle/Kawi Fire & Steel "Touring" Double saddle
Mapam forward controls
Kuryakyn Constellation LED driving lights w/turn signals
Kuryakyn ISO grips w/stiletto end caps
Kawi OEM backrest
Kawi Fire & Steel windshield
Bad Ace Billet handlebar risers
Signal Dynamics BackOFF XP brake light module
Tourmaster Coaster tool bag
CRU is offline
post #3 of 6 (permalink) Old 10-25-2018, 11:42 AM Thread Starter
Color: blue/silver
Drained oil thru oil screen. No it is not the grommet at the end of the screen. The o ring is larger than the grommet.
Thanks for your reply.
Tom
chipguy1 is offline
post #4 of 6 (permalink) Old 10-25-2018, 03:30 PM
Year/Make/Model: 2008 V900 Custom
Displacement/CC's: 900
Was the catch can clean when you started?
PERFORMANCE:
ECU reprogrammed by Ivan
Cobra Speedster Pipes
Barons BAK intake
Progressive springs in the forks.
COMFORT:
Kuryakn ISO Grips
Mustang Studded Wide Touring Seat with Driver Backrest
OEM Passenger Backrest.
MISC:
Added Grease fittings to Stem, Tie Rod, and Swingarm.
Cobra Crash Bar
Red LED lights by PO
170/80 Commander II in the rear
westcoastkevin is offline
post #5 of 6 (permalink) Old 10-25-2018, 04:19 PM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
it's 92055-1358 O-Ring
btom is offline
post #6 of 6 (permalink) Old 10-26-2018, 05:51 AM Thread Starter
Color: blue/silver
Yes I had just bought it.
chipguy1 is offline
change oil before or after winter storage? cannuk Oil and Lubrication 17 04-24-2018 09:30 AM
Oil drain bolt o-ring mumbles General Vulcan Talk 2 09-16-2013 01:29 PM
Vulcan 500 Runs Rough after Oil Change Xeronian Oil and Lubrication 3 08-17-2011 09:13 PM
help! oil leak after oil change... Toddster Vulcan 900 1 07-02-2010 08:52 PM
Some Smoke after Oil Change regnaston Vulcan 1600 2 04-21-2010 12:42 AM
