2007 VN1600 won't start - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
post #1 of 14 (permalink) Old 10-16-2018, 03:32 PM Thread Starter
Year/Make/Model: 2002 Vulcan
Displacement/CC's: 1600
Color: Maroon/beige
Help please! My 1600 classic was sitting for a couple of months during the winter. About 2 weeks back I tried to start it to get it ready for summer. It would not start and I ended up draining the battery. I decided to replace the battery with a new one and tried to start it again but still it would not start. I drained the new battery a couple of times already. I thought the fuel might be the problem so I drained the fuel tank and filled up with fresh fuel but still it would not fire up. What could be the problem?
Waggishfoxy is offline
post #2 of 14 (permalink) Old 10-16-2018, 04:21 PM
RastaPasta's Avatar
Year/Make/Model: 2006 VC1600 Mean Streak
Displacement/CC's: 1552
Color: Black
I'm not a mechanic, but some more info would help to troubleshoot.
Whats it doing when you try and start it? Does it crank but never actually kick over? Does it sound like it's not even really cranking?
What did you do with the fuel before storing it for the winter? Was it ethanol free fuel? Any additives? When you drained the tank did it looks separated or gummy or anything?
RastaPasta is offline
post #3 of 14 (permalink) Old 10-17-2018, 03:07 PM Thread Starter
Color: Maroon/beige
Hi RastaPasta. Any help, suggestion is appreciated. It cranks but that's it, it wont start. I made sure each time I tried to start it that the battery is actually fully charged to ensure it cranks normally, at full revolutions. Hope that makes sense.
The fuel was actally left inside of the fuel tank, I did not store it in a container or something. The fuel was 95 octane, no additives. I might be mistaken but the fuel had a "funny" smell to it hence my decision to drain the fuel tank and replace the fuel.
I meanwhile checked all fuses, all okay.
post #4 of 14 (permalink) Old 10-17-2018, 03:35 PM
1. How many miles on it?
2. How long have you owned?
3. Exactly how long was it sitting?
sfair is offline
post #5 of 14 (permalink) Old 10-17-2018, 03:49 PM Thread Starter
Color: Maroon/beige
Hi sfair
The bike has done just more than 11 000 kilometers - about 6 835 mile.
I bought it in 2016.
Last rode it about 4 months ago
post #6 of 14 (permalink) Old 10-17-2018, 08:21 PM
1. Any modifications...pipes, fuel processor, etc?
2. Any issues up to this point, no matter how unrelated?
sfair is offline
post #7 of 14 (permalink) Old 10-18-2018, 07:25 AM
DaPreacha's Avatar
Year/Make/Model: 2012 Kawasaki Nomad
Color: Red/silver
Check to see if you have spark at the plugs, also pull them and make sure they aren't gummed up from bad fuel. It could be as simple as a loose wire connection or a mouse chewed a wire in two. Look carefully in the headlight bucket at all the connectors and under the seat also. I once had a bared wire do the same on an 06 classic.
DaPreacha is offline
post #8 of 14 (permalink) Old 10-18-2018, 02:51 PM Thread Starter
Color: Maroon/beige
Hi sfair
100% stock, no modifications at all. Never had any issues of any kind with it. The previous winter it also sat for a couple of months. Although the battery then had lost some power, it started okay.
The only diference now is that I had replaced the battery. I did the swop as the manual said but could it be that something went rong there?
post #9 of 14 (permalink) Old 10-18-2018, 03:01 PM
1. Is this something you want to try and fix yourself, or?
2. Do you have a meter and know how to use it? No meter...we can help there too.
I do not recommend using the shotgun (look here, look there) method of troubleshooting because:
1. You can lose the problem only for it to show up again at night in the rain.
2. Another problem can be introduced and then the real tail chasing begins.
3. It rarely is successful.
sfair is offline
post #10 of 14 (permalink) Old 10-18-2018, 03:01 PM Thread Starter
Color: Maroon/beige
2007 VN1600 won' start
Hi DaPreacha
I did pull the spark plugs, they not bad really but did cleaned them up with some parts cleaner, have not checked for a spark though. Will do that and report back.
Also did check the wiring as far as possible, haven't checked the complete wiring bundle. Suppose I should take the time to check thoroughly.
Thanks for the advice
DaPreacha likes this.
New member ISSUE: Bike won't start and makes weird electric noise with start button Vulcaner Vulcan 900 19 12-18-2015 05:35 AM
2007 Meani won't start after filling gas tank jtiffany78 Vulcan 1600 6 04-25-2015 08:34 AM
Bike Won't Start, if it does, won't idle xantonin Vulcan 500 17 10-06-2012 07:49 PM
backfire on start up, now won't start. Help. WilburDink Vulcan 1500 2 06-11-2012 09:46 AM
Bike Won't START, clicks won't turn over. jimartina Vulcan 800 44 04-27-2011 04:17 PM
