newbie needs an assist - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 08-20-2018, 10:30 AM Thread Starter
Year/Make/Model: 2004 Kawasaki Vulcan 1600a Classic
Displacement/CC's: 1600
Color: ivory
hello all.....i am a recent Vulcan convert. Have a 2004 1600 Classic. I want to add hardbags with tail lights, some underneath led accents, a radio, and perhaps one or two more things to the rear. How much can my battery take ? I know nothing about the wiring on this bike, but i can follow instructions. Can i just wire everything to the battery or should there be a fuse, or something else between the new installation and the battery....MANY THANKS
mbennett603 is offline
post #2 of 9 (permalink) Old 08-20-2018, 01:27 PM
Reptilicus's Avatar
Year/Make/Model: 2008 Mean Streak
Color: Candy Fire Red
Anything connected to the battery should have a fuse. You will probably be fine with all that but check the current (amp) draw on the lights if you plan on using them with the motor off. That will give an approximate time the battery will last.
Reptilicus is offline
post #3 of 9 (permalink) Old 08-20-2018, 03:15 PM Thread Starter
Color: ivory
thanks....all of the accessories would only be on when the motor was running.
post #4 of 9 (permalink) Old 08-21-2018, 09:11 AM
andyvh1959's Avatar
Year/Make/Model: 2003 Vulcan VN1600 Classic
Color: Pearl Ivory
VN1600 have two alternators and enough wattage to handle most electrical additions. Also, Vulcans feature two accessory wiring connections in the wiring harness. Power for rear accessories is available on the White wire with the blue stripe. Power for front accessories is the Yellow wire with the blue stripe. Each circuit provides 120 watts of power on a 10 amp fuse, and each circuit provides power direct from the battery.
When life throws you a curve, lean into it!
andyvh1959 is offline
post #5 of 9 (permalink) Old 08-21-2018, 09:53 AM
CRU
CRU's Avatar
Only Nomads and Classics have two alternators. The meanie only gets one.
2008 Mean Streak Candy Fire Red
Vance & Hines Big Shots Staggered exhaust
Dyno tuned Power Commander III & K&N air filter
Corbin Young Guns saddle/Kawi Fire & Steel "Touring" Double saddle
Mapam forward controls
Kuryakyn Constellation LED driving lights w/turn signals
Kuryakyn ISO grips w/stiletto end caps
Kawi OEM backrest
Kawi Fire & Steel windshield
Bad Ace Billet handlebar risers
Signal Dynamics BackOFF XP brake light module
Tourmaster Coaster tool bag
CRU is offline
post #6 of 9 (permalink) Old 08-21-2018, 09:55 AM Thread Starter
Color: ivory
Thank you Andy...you saved me a great deal of time !! Will look for those connectors
post #7 of 9 (permalink) Old 08-21-2018, 10:25 PM
andyvh1959's Avatar
Color: Pearl Ivory
Thanks for the clarification on the Mean Streak versus the Classic and Nomad. I assumed all were the same.
Here are some wiring diagrams to reference:
Name:	VN1600 frt acc.JPG
ID:	224356   Click image for larger version
Name:	VN1600 rr acc.JPG
post #8 of 9 (permalink) Old 08-21-2018, 11:51 PM
bearslayer's Avatar
Year/Make/Model: 2004 Nomad , 1985 BMW K100 X2 , 1985 Intruder, 1998 Ducati Monster, 1972 CL350, 1948 Indian CZ125, 2
Displacement/CC's: 125 -1500
Color: Blue & Silver , Black , Gray , Maroon,black,
Unless I am mistaken if you plan to add Nomad style Hard bags you would have to change exhaust. Either that or do major surgery on the right hand bag. I did spot these that are similar that apparently fit a Classic
https://www.ebay.com/i/112819366773?chn=ps
That which does not kill me tends to really piss me off.
bearslayer is offline
post #9 of 9 (permalink) Old 08-22-2018, 06:52 PM
andyvh1959's Avatar
Color: Pearl Ivory
I have a pair of Nomad bags I will be mounting on my Classic, using my own design to mount the bags and not require the big heavy bag mount frame system. But that also means I have to design a mount system for the dual mufflers in place of the Vance & Hines Bigshots on the right side of the bike now. Lots of work to do this winter.
Kuryakyn Mechanical throttle Cruise Assist Abnuceals Vulcan 900 3 04-06-2013 10:33 PM
Kuryakyn Throttle Assist ophidia Vulcan 2000 15 04-04-2013 08:10 PM
Rear Suspension Assist Fointwinder Vulcan 500 5 04-05-2012 06:25 AM
Kuryakyn mechanical Throttle Cruise Assist install HELP! Curly Vulcan 1600 1 02-26-2012 01:58 PM
