Help with Changing Handlebars to Mini Apes - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 03-19-2018, 06:26 PM Thread Starter
Year/Make/Model: 2008 Kawasaki Vulcan 1600 Classic
Displacement/CC's: 1600
Color: Diablo Black
Greetings All,
Im a new motorcycle owner. I have a Vulcan 1600 Classic. I am 64 & 300lbs. I know my handlebars are 1 other than that Im not sure where to start. My current handlebars are stock. Im thinking I want 10 mini apes. Not sure what brand or style. No sure if I need risers or if I need to extend the cables and how to measure for that. Any info would be greatly appreciated.
TTOTHEB is offline
post #2 of 6 (permalink) Old 03-19-2018, 07:06 PM
BOTM Winner
December 2016
Luckymann77's Avatar
Location: Where the Horses Are Fast and the Grass is BLUE !!!
Ttotheb,
Welcome to the forum...
Suggest you use the search feature in the top right corner...
The 1600’s came out in 2003 so 15 years of mods and such are available...
Plus the Vulcan Gadget webpage...
The short answer is yes you can add ape hangers, for a price...
Going too high will cost a lot...
You’ll have to get new throttle cables, longer brake lines, longer clutch lines and extend all the wiring on both left and right sides of the bars...
Could run you in excess of 500 bucks...
Research it and you might find a compromise by rerouting everything under the triple tree and not go so high...
Good luck in your endeavor!!!
Let’er BUCK !!!
Seven O’ Nine !!!
Luckymann77
I love you more today than I did yesterday...
Yesterday you really PISSED ME OFF !!!
Long Time Rider...
First Time Vulcan Owner...
2005 Vulcan 1600 Classic
Majestic Metallic Red
Bagged up !!!
Chromed and Studded out !!!
Big 3
Cobra Dragsters
Cadmann
Wiseco/Doebeck EJK
Luckymann77 is offline
post #3 of 6 (permalink) Old 03-21-2018, 07:12 PM
Kei41's Avatar
Year/Make/Model: 2007 Kawasaki Vulcan
Color: Black
I just added santee's 11" dresser Apes I'm 6'4 330 they're very comfortable I got them for $70. They're a 2" bar but cut down to a 1" on the grips and the mounting area so you can use your stock risers. I did end up having to get longer front brake line the clutch line fits but it's tight and I'm about to replace that with a longer one while I was at it I bought new rear brake line all the lines are galfer steel braided lines big Improvement Overstock rubber lines. Hope this helps good luck man!
Kei41 is offline
post #4 of 6 (permalink) Old 05-29-2018, 11:22 PM
Update? I have some 10 inchers that I haven't tried to install yet and want to know how yours went
Benjaja is offline
post #5 of 6 (permalink) Old 05-30-2018, 09:40 PM
BOTM Winner
December 2016
Mine are listed at 9.5" rise and I added an additional 1" riser extension...
You should be OK with a 10" rise...
If you try it and it doesn't work, you can reroute whatever line/wire that is the issue to "under the triple tree"...
Without having to purchase anything additional...
Let'er Buck,
Seven O'Nine!!!
Luckymann77
Long Time Rider...
Bagged up !!!
Big 3
Cobra Dragsters
Cadmann
Wiseco/Doebeck EJK
post #6 of 6 (permalink) Old 06-07-2018, 07:30 PM
I installed some 10inch apes and my clutch cable is still very tight. I know this sounds simple but to get it to fit I literally cut the zipties connecting it to the frame on the right side, and pulled it through to the left side behind the radiator directly to the handlebars.
This is not right is it? If anyone would please show me or coach me on what Im doing wrong Id be eternally grateful
Benjaja is offline
Help with mini apes on a 2004 classic 1600 Bikerdude53 Vulcan 1600 9 11-12-2013 01:18 PM
mini apes cable length? foxbat Vulcan 800 18 02-27-2013 05:16 PM
mini apes storms Vulcan 900 19 08-20-2012 09:31 AM
Anyone tried Mini-Apes Mr. Weed Vulcan 2000 6 09-16-2010 09:07 AM
winter mini-apes project is done Slpr61 Vulcan 900 3 03-04-2009 03:34 PM
