06 nomad with 06 meanie motor - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 02-27-2018, 07:09 AM Thread Starter
extreemthrottle's Avatar
Year/Make/Model: 2006 kawasaki vulcan nomad
Displacement/CC's: 1600
Color: black
my nomad motor was having 2nd gear and clutch issues, so instead of spending around 2k i decided to pick up a used motor. i stumbled on a 06 mean streak motor that has a muzzy big bore, thunder cams, ported head, intake and modded throttle body, cobra pipe and bak. it also had a pc3 installed. i purchased it and the pc3 after a lot of back and forth questions etc.. the pc3 ended up getting lost in the shipping crate and was never found. so i purchased the pc5 and after installing the motor drove it to the dyno shop to get tuned.
the shop has been unsuccessful in tuning the pc5 to the bike as it still pings on the top end of the rpm range, they have suggested the need to adjust the timing to eliminate this, but i have only found one company in italy that makes a system to do this. i was hoping to find someone to flash the ecu for what i need, but i havent found anyone. i tried ivan's but he doesnt do them for the 1600.
any suggestions?
extreemthrottle is offline
post #2 of 5 (permalink) Old 02-27-2018, 10:20 AM
Did the dyno use an exhaust gas analyser?
sfair is offline
post #3 of 5 (permalink) Old 02-27-2018, 12:17 PM Thread Starter
Color: black
yes, one for each cylinder. he said he couldnt make it rich enough to go away.
im hoping to get the mean streak ecu and it takes care of the issue, since it ran fine in the other bike with a tune on the pc3
post #4 of 5 (permalink) Old 02-27-2018, 12:26 PM
I did not notice that you were using the Nomad ECU.
Definitely need the ECU that matches your engine.
Post back with results.
sfair is offline
post #5 of 5 (permalink) Old 02-27-2018, 04:54 PM Thread Starter
Color: black
i hope that takes care of it
06 meanie McArthur80 Vulcan 1600 0 01-16-2017 09:11 PM
motor oil for 2006 nomad 1600 johannrods Engine Work 4 08-19-2013 09:25 PM
Looking for 1600 meanie motor or heads. sockrdoc Vulcan 1600 0 08-26-2010 03:29 PM
'99 Nomad motor swap dbianchi Vulcan 1500 9 08-03-2010 03:56 PM
HI I have a 1500 nomad 03 am rebuilding motor RUSSWING Engine Work 0 04-23-2010 08:37 AM
