LED load equalizer - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 04-25-2017, 06:42 AM Thread Starter
mooserd's Avatar
LED load equalizer
Going to change out my turn signals to LEDs. Do I need to run load equalizer for each side, or run one load equalizer for the pair?? Front, Rear turn signals? Advance auto said I had to run one load equalizer per led light. Any help would be great
Vic
2007 Vulcan Nomad 1600
mooserd is offline
post #2 of 4 (permalink) Old 04-25-2017, 07:03 AM
Color: Black / grey
Yep each bulb needs its own load resistor.
vulcandoc is offline
post #3 of 4 (permalink) Old 04-28-2017, 08:03 AM
rangemaster728's Avatar
Year/Make/Model: 2016/Kawasaki/Vulcan S ABS
Displacement/CC's: 649
Color: Urban White
LED load equalizer
UNLESS...you change out your turn signal relay to one that is LED-compatible, then typically no load resistors needed.
See this thread for a general explanation...
Retrofit LED Lamps for Existing Turn Signals- Turn Signals 101
https://r.tapatalk.com/shareLink?sha...5&share_type=t
Electrical Engineer
2014 HD FLHTK
2013 BMW K1600GTL
2016 Vulcan S ABS
rangemaster728 is online now
post #4 of 4 (permalink) Old 04-28-2017, 08:18 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
i tried 1 load equalizer per each side pair, total 2 equalizers for system, it did not work with just 2, I heard someone say you need total 4 equalizers for whole system, 1 for each led light
btom is offline
Load equalizer vs. new flasher relay OldDave Vulcan 900 5 03-10-2014 08:56 AM
LED turn signal with LED license frame needs load equalizer ? evodog Vulcan 900 20 07-12-2012 07:20 AM
Is a load equalizer needed>>>///WHY?? BlackedOutVulcan Vulcan 900 0 08-16-2011 12:40 PM
Load equalizer Is it needed? BlackedOutVulcan Vulcan 900 1 08-15-2011 09:53 PM
Considering a Voyager. Load capacity? hotelwhiskey Vulcan 1700 6 03-02-2010 07:24 AM
