No braking power after new pads installed - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 04-09-2017, 07:04 AM Thread Starter
Jau Jay's Avatar
So like the title says, I installed new sintered pads on the front and rear deglazed the rotors cleaned them off as well, lever and rear brake have pressure so what gives? Feels like oil or something on the discs but cant be i used brake clean on them. I went for a quick spin and there's hardly any stopping power but lots of pressure on the front and rear brakes. Thanks for your help.
Sent from my SM-G935W8 using Tapatalk
Jau Jay is offline
post #2 of 10 (permalink) Old 04-09-2017, 09:43 AM
1. How many miles on the bike?
2. How did you de-glaze?
3. Any rotor scoring/ridges?
4. What brand of pads?
5. Front and back the same?
sfair is offline
post #3 of 10 (permalink) Old 04-09-2017, 10:13 AM
Year/Make/Model: 2007 Mean streak SE
Displacement/CC's: 1600
Color: black/red
Seems like you covered most of the bases so far but I would drive for 100 miles or so to break the pads in and if they don't seem better start by bleeding the brakes there could be a bubble even though you said they had good pressure. Also some aftermarket pads are just crap.
doh13 is offline
post #4 of 10 (permalink) Old 04-09-2017, 10:18 AM Thread Starter
Jau Jay's Avatar
Ya i was thinking that as well. Like i said it was a very short ride and it just caught me off guard applying the brakes and not having much going on. Ill give it more time and if no improvement ill swap them out.
Jau Jay is offline
post #5 of 10 (permalink) Old 04-09-2017, 10:35 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
whenever I change pads I never touch or clean the rotors, I leave them as is and never have a problem
btom is offline
post #6 of 10 (permalink) Old 04-09-2017, 12:34 PM
rangemaster728's Avatar
Year/Make/Model: 2016/Kawasaki/Vulcan S ABS
Displacement/CC's: 649
Color: Urban White
The pads need to be bedded...I'd start there:
https://ebcbrakes.com/articles/motorcycle-bed-in/
Sintered pads (especially ones that are rated HH) take longer to break in than organic or semi-metallic pads.
Ride safe!
Electrical Engineer
2014 HD FLHTK
2013 BMW K1600GTL
2016 Vulcan S ABS
rangemaster728 is offline
post #7 of 10 (permalink) Old 04-11-2017, 10:59 AM
Not sure if I agree about the bedding in being the problem. Although it is true that pads need to be bedded to achieve maximum performance, I have installed EBC HH pads on several bikes and have had immediately good braking. Sure it gets better after they are bedded in, but they should be pretty good from the get go.
Ahemsa is offline
post #8 of 10 (permalink) Old 04-11-2017, 11:01 AM Thread Starter
Jau Jay's Avatar
Thanks for all the replies i think I'll just give it some time and see if it gets better.
Jau Jay is offline
post #9 of 10 (permalink) Old 04-11-2017, 11:04 AM
Hot Cruiser's Avatar
Brake pads usually take a bit of time and a number of stops before they work as they should. New cars usually have instructions to be careful and to avoid hard stops for a set number of miles so the brake pads and discs can break in properly.
Jesus is Lord
Hot Cruiser is offline
post #10 of 10 (permalink) Old 04-11-2017, 11:16 AM
What is funny about that is that for many high performance pads, you specifically want to make a series of hard stops to properly bed them in. I always go for aggressive high performance pads on my vehicles. If I bring it back from a first ride and I can't smell the pads, I didn't break them in right
Of course from the factory they generally don't install what I would consider a high performance pad, so that is the difference.
Ahemsa is offline
No power to headlight after starter solenoid replacement slickaudio Vulcan 2000 1 09-01-2016 08:22 PM
Lost my braking power in the front .. Need help w troubleshooting 10grandstan Vulcan 500 17 11-27-2015 08:59 PM
How to Slow Down (Engine Braking vs Braking) Eddy New Riders 43 08-21-2015 07:28 PM
No power after disengaging kill switch (electrical) XenosoniK Vulcan 900 7 07-24-2012 07:41 PM
Loss of power after new chain installed Redneck336 Vulcan 500 5 03-16-2011 01:55 PM
