Adding a USB port - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By Vernon
post #1 of 2 (permalink) Old 03-21-2017, 12:16 PM Thread Starter
Adding a USB port
So I got tired of plugging and unplugging my USB every time I went on a ride. So here is what I did.
I went on line and found a electrical schematic for my 2007 1600 Nomad.
I needed a circuit that was only hot when the engine was running.
I traced out the head light circuit. I followed it back to the junction box located behind the cover panel by my right thigh.
Turns out to be the blue wire with the yellow stripe.
Using my volt meter I verified that it it was the right wire. I checked continuity between the headlight fuse and the b/y wire. And then checked for voltage with the key off and then key on and engine running. I needed to make sure that when the ignition was off there was no voltage to that wire, but when the ignition is on and the engine running it is on.
I used a splicing connector to connect the positive wire from the USB to the B/Y wire. Then connected the other wire to the frame under the seat.
I hope this helps someone else. I looked and haven't found this kind of help anywhere.
Buskman likes this.
Vernon is offline
post #2 of 2 (permalink) Old 03-22-2017, 11:17 AM
downinthefrontrow's Avatar
Year/Make/Model: 05 Kawasaki nomad
Displacement/CC's: 1600
Color: Blk/silver
Send a message via MSN to downinthefrontrow Send a message via Yahoo to downinthefrontrow
I also put a USB/CIGGS. LIGHTER SOCKET,I RAN A POSITIVE STRIGHT FROM BATTERY W/IN LINE FUSE AND NEG. FROM FRAME BOLT THEN MOUNTED IT ON BARS,NOW I CAN PLUG IN USB CABLE TO PHONE AND PUT PHONE IN TANK BIB POCKET..INSTALLED A TACH. LAST WEEK, I HAD TO GO INSIDE HEADLIGHT BUCKET TO FIND A SWITCHED HOT WIRE AND IF I HAD TO DO IT OVER, I WOULD HAVE FISHED MY WIRES UNDER TANK & RUN WIRES FROM BATTERY POS.AND FRAME GND.6 OF 1, HALF DOZEN OF OTHER
downinthefrontrow is offline
Looking for Advice on adding a USB Port 2K4V2K General Vulcan Talk 10 01-13-2012 07:37 AM
Adding a cig lighter port.. edmKC Vulcan 900 9 07-29-2011 09:29 PM
Port Dover: Friday August 13th groomergirl Rides 2 05-23-2010 09:27 PM
Port and Polish heads IL-VN800A9 Vulcan 800 2 04-08-2010 10:28 AM
Hello from Port st lucie. tcrider New Member Introductions 5 09-18-2009 06:32 PM
