10 cent quick fix for broken sidecover post - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 1 Post By 08Nomad
  • 1 Post By Bandit
post #1 of 3 (permalink) Old 07-30-2016, 03:07 PM Thread Starter
ElCaganer's Avatar
Year/Make/Model: 2005 Kawasaki Vulcan Classic
Displacement/CC's: 1600
Color: Metallic Beige
When I bought my '05 Vulcan Classic one of the little things that needed fixing was that the little plastic post that holds the sidecover in position on the left side was broken. The key lock held the cover on, but it was loose and moving around quite a bit. After looking at for a sec I had an idea for a quick fix. This ain't no showman job, it's a rig, but it worked and only took about 5 minutes, and no one will know it's done as it inside the locked cover.
What I did was grab one of the many lightweight wall anchors (for hanging pictures on sheetrock) that are lying around in my garage and found one that would fit into the grommet hole where the plastic post would go. I then drilled a hole in the post's old location (there's a perfect little stand-off area there that made this work), then screwed the anchor screw in from the back, then screwed the plastic anchor on to that. The new "post" is the same size as the missing post, and fits perfectly into the grommet and completed secured the side cover. One of these days I'll buy a new sidecover to replace it, but this works fine for the meantime.
Here's some step by step pics:
Toolbox area with cover off, grommet hole above keyhole on right.
Here's what I used for the fix
Testing to see that the anchor is the right size for the grommet hole
The back side of the side cover. The pin would normally stand up from where that hole is, if it weren't broken off and missing. I had already drilled the hole before I started taking pictures.
Getting the screw in behind the standoff and into the hole I drilled
The finished fix. The anchor stands in for the pin, and the swell of it in the middle once the screw is in helps it stay tight.
Ok, there goes today's Cheap Fix. Back out to the garage!
ElCaganer is offline
post #2 of 3 (permalink) Old 07-30-2016, 06:51 PM
Excellent idea and fix. Very creative!
ElCaganer likes this.
08Nomad is offline
post #3 of 3 (permalink) Old 07-30-2016, 08:23 PM
Bandit's Avatar
Year/Make/Model: 2014 Vulcan 900 Custom - 2018 Yamaha XT250
Displacement/CC's: 900/250
Color: Candy Lime Green - Sandy Beige
Very good fix.Nice work.
2014 Kawasaki Vulcan 900 Custom
2018 Yamaha XT250
Bandit is offline
Top 10 New Motorcycles Around $10,000 motorcycle.com Vulcan Forums News 0 10-16-2017 01:16 PM
tried a quick post but would not post to the thread 07 buffalo Vulcan 2000 0 02-06-2015 11:47 AM
Just Ride 10/10 uride2 Rides 0 10-08-2012 05:16 AM
Any other quick windshield quick release solutions? Bobh344 Vulcan 1700 2 03-13-2012 09:38 AM
