06 Vulcan cutting out - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 20 (permalink) Old 06-01-2016, 06:55 AM Thread Starter
Year/Make/Model: 06 Vulcan Classic
Displacement/CC's: 1600
Color: Black
I installed a new battery a couple weeks ago. Since then I've been having problems. When my engine is cold it gives my a little crap starting up. I can take off fine but as soon as I shift into second it's starts cutting out and will usually die. While this is happening the red light on my speedo comes on.
It only lasts for a few blocks and then everything is fine.
I can find my way around a car engine but I'm out of my element with a motorcycle. It's really nice out and I don't want to ride in fear of messing something up further. I posted on Reddit but figured this would be the best place to ask. Here is my original post copy and pasted:
It all started after I put in a new battery. I have checked the connections on the battery everything is tight and where it should be.
With a cold engine it will cut out and sometimes die and the red temp light will turn on while it's happening. No problems after a couple minutes of riding. I've checked the plugs they look good. Oil levels are good. Radiator is full.
It also hesitates a bit before starting. Normally it will fire right up, now it's cranking several times before starting.
I blew through the tank vent hoses and they are clear.
Everything appears to be a fuel system problem however all of my experience is with cars. This is my first bike, other than a new battery, an oil change, and tightening the bolts holding the fuel pump on (minor gas leak when it would sit over night) I've had to do nothing to it in the last year I've had it.
Update: Just took it for a short 2 mile ride. When I shift into second is when the problem seems to present itself. But after dying twice in 3 blocks and a few more bog downs it straightened up.
A mind needs a book as a sword needs a whetstone, if it is to keep its edge.- Tyrion Lannister
Shakesfear is offline
post #2 of 20 (permalink) Old 06-01-2016, 04:40 PM Thread Starter
Color: Black
I pulled the cover to test the stator. So uhh which one of these plugs do I stick my prong in? There's a write up on the Vulcan 900 forums I read, however it says 3 white wires. I have 3 plugs here 1 has black wires 1 has yellow with black stripes and 1 has black with red, yellow, and white stripes.
post #3 of 20 (permalink) Old 06-01-2016, 04:47 PM Thread Starter
Color: Black
Alright stuck the prongs in the plug closest to me with the 3 black wires. Set on AC at idle was was reading 23, revved up it went to 110-111.
Edit: Found a service manual online. I was testing the correct plug for the stator. My Voltage seems to be high though. The manual says 60-90 at 3000 RPM, granted i dont have tach I just revved it slightly.
post #4 of 20 (permalink) Old 06-01-2016, 05:59 PM
revrider's Avatar
Year/Make/Model: 2010 NOMAD
Color: Black/titanium
Sounds more like a fuel prob,it is fuel injected ,no?sure it's not the FI Light?
revrider is offline
post #5 of 20 (permalink) Old 06-01-2016, 06:13 PM Thread Starter
Color: Black
It has a choke so I'm thinking its carbed. Ugh the more I talk the more I realize I know so very little about my bike.
My first thought was fuel. I started to steer away from that when I hooked up a battery charger on 10 amps and it fired up first turn over.
Battery is reading 12.4 volts idle and 13.6 when revved.
I'm so lost at this point.
I just wanna ride!
post #6 of 20 (permalink) Old 06-01-2016, 06:21 PM
Near the battery, you should find a bundle of black/yellow wires that terminate in an orange colored plug. Check to see if the plug looks burned or scorched.
sfair is offline
post #7 of 20 (permalink) Old 06-01-2016, 06:21 PM
revrider's Avatar
Must b carb then,Hopefully sfair will chime in,He is the man,ask ya make model any mods and if u have a meter,lots of help here,would also add some seafoam to the fuel,help clean out some crud you might have
revrider is offline
post #8 of 20 (permalink) Old 06-01-2016, 06:23 PM
That bike is fuel injected.
sfair is offline
post #9 of 20 (permalink) Old 06-01-2016, 06:33 PM Thread Starter
Color: Black
I'm not seeing a bundle of black/yellow wires. I did however find a single black wire with a yellow stripe that looks like it plugs into another identical wire. No scorching but they were unplugged. Not sure why or what they are.
post #10 of 20 (permalink) Old 06-01-2016, 06:35 PM Thread Starter
Color: Black
Good to know. I have never seen EFI with a choke. Like i said though I am new to working on motorcycles.
'03 Vulcan 500 - Cutting out on the freeway lkilgoretrout Vulcan 500 9 09-24-2014 09:19 PM
2009 EN500LTD is cutting out newbierider Vulcan 500 6 09-07-2011 07:48 AM
Engine cutting out cloudrider General Vulcan Talk 2 06-09-2011 01:02 PM
cutting out/back-firing? scarpacci Vulcan 800 31 05-02-2011 08:15 PM
2001 1500 fi cutting out at speed ifly15 Vulcan 1500 9 01-23-2011 03:22 PM
