Shaft drive lag - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
post #1 of 12 (permalink) Old 05-19-2016, 07:23 PM Thread Starter
Combat_Infantryman's Avatar
Year/Make/Model: 2005 Kawasaki Vulcan 1600 Classic
Displacement/CC's: 1600
Color: Black
Shaft drive lag
Hello, I have an 05 Vulcan 1600 with 8000 miles. I added a set of Vance and Hines and a power commander 3. The bike sounds and rides good but. When I get on it, it seems like the engine is revving up too much for the shaft drive to keep up with. I'm not sure how to really explain it but it reminds me of turbo lag on an older diesel truck so I am thinking shaft lag.
Any advise or suggestions would be greatly appreciated.
New to me as of 3/1/2016. It is bone stock with 6600 miles.
I ordered new Metzler tires, Cobra Fatty Highway Bars, Kuryakyn Pegs, Power Commander 3 and V&H Big Shots.
Combat_Infantryman is offline
post #2 of 12 (permalink) Old 05-19-2016, 07:27 PM
I have an 04 1600 classic. I dont have them issues except in 5th gear it feels like its over drive.pulls great in other 4 gears. 5th is just slow to go any faster real fast.but it did put me in mind of a diesel .funny you said that.
Combat_Infantryman likes this.
Bigbigdaddy669 is offline
post #3 of 12 (permalink) Old 05-19-2016, 07:55 PM
Year/Make/Model: 2016 Kawasaki Voyager; 2004 VFR800; 2003 VTX 1300
Color: Phantom/Spark
If the motor is revving up but not transferring power to the rear wheel your clutch is slipping. It could be weak springs, worn clutch plates, or quite possibly the wrong type oil.
"A good long ride can clear your mind, restore your faith, and use up a lot of fuel"
"I believe in treating everyone with respect, but, first you have to get their attention"
Never be ashamed to unlearn an old habit...
gearhead759 is offline
post #4 of 12 (permalink) Old 05-19-2016, 08:10 PM Thread Starter
Color: Black
It only happens in 5th gear for me too.
post #5 of 12 (permalink) Old 05-19-2016, 09:54 PM
Remove the clutch master cylinder top and peer down to the bottom.
There you will see two small holes.
Take a fine wire or bristle and make sure they are clear.
Now would be a good time to flush and replace the fluid in the clutch and both braking systems.
At 8000 miles, I would not suspect clutch spring nor worn clutch, yet.
sfair is offline
post #6 of 12 (permalink) Old 05-19-2016, 10:03 PM Thread Starter
Color: Black
Thank you, I'll check that out.
post #7 of 12 (permalink) Old 05-20-2016, 05:02 AM
I really think its just the nature of it. I like the fact once im in 5th it doesnt feel like it needs another gear. I had an 800 intruder that screamed in 5th . This one i just make sure I get the speed I want before 5th.
post #8 of 12 (permalink) Old 05-27-2016, 07:14 PM
mckeownpt's Avatar
I have the same issue with my 03 Classic, I am convinced it is the clutch slipping. I am going to judge Washers and Meanstreak clutch on my classic. (81,000 miles)
03 Kawasaki Vulcan 1600 Classic
1976 Honda GL1000
mckeownpt is offline
post #9 of 12 (permalink) Old 08-05-2016, 03:30 PM Thread Starter
Color: Black
Update.... I rode around for a while and the slipping got worse. My buddy installed a new clutch assembly and a Barnett spring. It rides like a champ now.
post #10 of 12 (permalink) Old 08-05-2016, 05:27 PM
If you had a clutch fail at that mileage, I am suspecting for some reason...like a plugged relief port, etc. Unless, of course, if it was severely beat on...
I would try to determine why it failed or the new unit will meet the same fate.
sfair is offline
Throttle lag? Glenn54 Vulcan 1700 5 02-10-2015 07:12 PM
Throttle lag? Glenn54 Vulcan 1700 1 02-10-2015 05:10 PM
WTB Final Drive and drive shaft. ClassicFnAllen Vulcan 750 0 09-20-2011 07:55 PM
EN500C (2005) Throttle Response lag? FL500c Vulcan 500 12 10-27-2010 11:24 PM
New Lag Time on this site Rageous Community Help 8 08-24-2010 01:32 PM
