06 1600 Nomad - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 12 (permalink) Old 05-10-2016, 05:25 PM Thread Starter
06 1600 Nomad
Feels like my bike is slipping. 40 or 50 mph if I give it throttle the engine revs and it feels like it slipping. It's in gear but it takes a while to gain speed. I was talked into using amsoil 20-50 synthetic oil last year. I switched back to factory recommended Bel Ray conventional oil. Anything I can do besides changing the clutch?
Jvboots is offline
post #2 of 12 (permalink) Old 05-10-2016, 06:54 PM
How many miles on it?
sfair is offline
post #3 of 12 (permalink) Old 05-10-2016, 07:11 PM Thread Starter
Just under 10k. Had 2300 when I bought it a year ago.
Jvboots is offline
post #4 of 12 (permalink) Old 05-10-2016, 08:49 PM
Any difference with the oil change?
sfair is offline
post #5 of 12 (permalink) Old 05-10-2016, 09:08 PM Thread Starter
Only when cold, the longer I ride the worse it gets. Had a tough time keeping up with friends a few days ago.Going to put bout 1000minutes and change oil again and see how it is.
Jvboots is offline
post #6 of 12 (permalink) Old 05-10-2016, 09:09 PM Thread Starter
1000 miles !!
Jvboots is offline
post #7 of 12 (permalink) Old 05-10-2016, 09:20 PM
If you can get bandit101's attention, I am not sure if later bikes suffered from weak clutch springs, or not.
sfair is offline
post #8 of 12 (permalink) Old 05-11-2016, 08:22 AM
Bandit101's Avatar
Year/Make/Model: 2015
Displacement/CC's: 103ci
Color: Black
I am unaware of any deficiency with clutch springs for that model. I can assure you that if you continue to ride it with it slipping you
will need a new set of clutch disc, and that still will not fix the problem.
Questions: Did the bike start slipping after you changed back to conventional oil?
You are saying that the longer you ride the worse it gets, is this only when you try to accelerate? If you come to a complete
stop and take off again, is it slipping in all gears, or only after you have gotten to 5th.
Has anyone ever been into the clutch before?
Bandit101 is online now
post #9 of 12 (permalink) Old 05-11-2016, 01:06 PM
Worse when hot? Then:
1. Remove cover from clutch master cylinder.
2. Peer down to the bottom and you will see two small holes.
3. With a piece of nylon bristle or copper wire, carefully run through and make sure holes are clear.
4. Now is a good time to flush and replace fluid in clutch and both braking systems. Your clutch is telling you this.
Post back with any questions.
sfair is offline
post #10 of 12 (permalink) Old 05-11-2016, 01:23 PM
Bandit101's Avatar
Color: Black
That is what I was also suspect of. Was waiting to hear answers
to my questions.
06 nomad with 06 meanie motor extreemthrottle Vulcan 1600 4 02-27-2018 04:54 PM
06 1600 nomad fuel pump noise Randall Jones Vulcan 1600 13 06-16-2014 09:00 PM
'06 1600 Nomad stock exhaust complete. markclark57 Bikes For Sale 11 03-14-2011 12:44 AM
06 1600 nomad fuel pump noise Randall Jones New Member Introductions 3 08-15-2010 09:55 AM
upgades for 06 vulcan nomad 1600 mark06nomad Vulcan 1600 7 01-27-2010 03:57 PM
