1600 Vulcan classic fuel problem - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 36 (permalink) Old 03-25-2016, 09:14 PM Thread Starter
Recently my 1600 Vulcan classic fuel injected bike start up letting it warm up before riding started dumping raw fuel out of the exhaust pipe not just a little but a lot of fuel, the plugs on the front cylinder are firing I'm stuck trying to figure out the problem any one have any clues
jay79618 is offline
post #2 of 36 (permalink) Old 03-25-2016, 09:26 PM
Does it have a fuel processor installed?
sfair is offline
post #3 of 36 (permalink) Old 03-26-2016, 08:37 PM Thread Starter
Yes.I took it off and it still does the same thing
jay79618 is offline
post #4 of 36 (permalink) Old 03-26-2016, 10:04 PM
Post a picture of the firing end of the spark plugs.
sfair is offline
post #5 of 36 (permalink) Old 03-26-2016, 10:08 PM Thread Starter
With it firing or just the end of the plug
Sent from my SCH-S968C using Tapatalk
jay79618 is offline
post #6 of 36 (permalink) Old 03-26-2016, 10:10 PM Thread Starter
The end of the plug is wet when I pull it out I use a spark tester to make sure it was firing
jay79618 is offline
post #7 of 36 (permalink) Old 03-26-2016, 11:00 PM
Clean and dry plugs and then swap them front to back and see if problem moves.
sfair is offline
post #8 of 36 (permalink) Old 03-26-2016, 11:04 PM Thread Starter
I've put new plugs in it to since then to see If the plugs were fouled or had just broke down. I've put new injectors in it in case they were stuck open
jay79618 is offline
post #9 of 36 (permalink) Old 03-27-2016, 10:10 AM
Yikes! Throwing parts at a problem is a quick way to lighten your wallet and make no headway.
What else have you done so far?
sfair is offline
post #10 of 36 (permalink) Old 03-27-2016, 10:41 AM Thread Starter
That's about it I hope its not the Ecm
jay79618 is offline
2007 Vulcan 1600 Classic Fuel filter Pump ideas? niteowl Vulcan 1600 2 06-29-2016 01:49 PM
1600 Vulcan classic fuel problem jay79618 New Member Introductions 1 03-25-2016 08:35 AM
Fuel Tap Problem - Petcock Problem Brewster_440 Vulcan 800 0 04-11-2014 08:46 PM
Fuel smell on a 2004 Vulcan Classic 1600 pearlcrystalwhite16 Vulcan 1600 0 08-21-2009 08:15 AM
Vulcan 800 Classic Fuel Problem CodeJockey General Vulcan Talk 1 03-23-2009 08:42 AM
