completely dead..NEED HELP - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 02-28-2016, 03:03 PM Thread Starter
pittdave's Avatar
I guess its my turn to have a serious electrical issue
06 1600 Classic.. went to ride today, turned the key on and upon hitting the start button. everything went dead..tried again same result.. lights and all were coming on but all would go dead once i hit the start button.
I hooked up the battery tender and it said 'charge aborted - bad battery' OK.. Off to the store to get new battery. Upon hooking up new battery..no nothing..no lights..nothing.. I tested the old battery on multimeter and it still read 12.4 V. Before taking it out.. i tested on the MM and it read 3.3V. I have since tries the old and new battery and have nothing with the turn of the key
I have tried even hooking cables to the terminals and leavng the battery out so as not to have to go through the hassle of trying to get the battery in the compartment
So now I dont know what is going on...Need some ideas as to what to look at next
At one point, i heard two small 'pop/clicks' when hooking things up.. I have checked all fuses in the right side box and the 15a in the compartment..they are all fine
As a side note.. i had been having some issuse with blowing the 10a acc fuse but i thought i had that correected as it has been out a few times since then
Whats the next thing to look at to at least get something to light up
THX
PD
2003 Vulcan 1600 Classic
"always time to ride"
pittdave is offline
post #2 of 7 (permalink) Old 02-28-2016, 05:23 PM
Greg_C's Avatar
Year/Make/Model: 2006 Vulcan Mean Streak
Displacement/CC's: 1600
Color: Black
There is a 30A main fuse accessible inside the battery compartment... Check this fuse if all circuits are dead.
Greg
Halifax Nova Scotia Canada
Current Ride: 2006 Vulcan 1600 Mean Streak
(Work in progress)
Past Rides: HMCS Assiniboine DDH 234
Greg_C is offline
post #3 of 7 (permalink) Old 02-28-2016, 06:18 PM Thread Starter
pittdave's Avatar
It is INSIDE the battery compartment??? I saw a 15a with a spare 15a with it but did not see a 30a.. i will check again
pittdave is offline
post #4 of 7 (permalink) Old 02-28-2016, 07:12 PM Thread Starter
pittdave's Avatar
Ok... found the main fuse.. yep it was blown.. replaced and we have main power back.. still not turning over but the tender says battery is at 40%.. I'll let it charge and see what happens
pittdave is offline
post #5 of 7 (permalink) Old 02-28-2016, 08:19 PM Thread Starter
pittdave's Avatar
Oh that glorious moment when the enginr fires back up and all is well.. Time to take back a battery
pittdave is offline
post #6 of 7 (permalink) Old 02-29-2016, 10:10 AM
Bandit101's Avatar
Year/Make/Model: 2015
Displacement/CC's: 103ci
Color: Black
There is a reason the main fuse was blown. I would do some serious testing, as the next time you may find yourself a couple of hundred miles from home after dark. Be sure and carry spares.
Bandit101 is offline
post #7 of 7 (permalink) Old 03-01-2016, 09:18 PM Thread Starter
pittdave's Avatar
what kind of testing... im not the best in electronics..where should i look
pittdave is offline
Completely dead Wadegster Vulcan 1700 6 08-14-2014 10:12 AM
Electrical Completely Dead Freshlimes Vulcan 1500 12 02-11-2012 07:27 AM
Electrical System Completely Dead Condor54 Vulcan 1500 2 09-14-2011 10:54 PM
Help totally vexed!Dead 1500-reads like dead short louichie Vulcan 1500 1 05-28-2010 01:39 PM
Rear mud guard COMPLETELY destroyed qdude1 Vulcan 900 4 07-22-2009 09:48 PM
