Finding ignition wire or similar - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 02-26-2016, 04:12 PM Thread Starter
saffer's Avatar
Year/Make/Model: 2006 Vulcan Nomad
Displacement/CC's: 1600
Color: Black
Just received my Shark audio system today-hoping to hook it up over the weekend. Don't want to run it directly to the battery, but rather come on only when the ignition is turned on.Can anyone tell me the best wire to connect to (under the seat-don't want to mess around with headlight bucket etc) pls advise location,colour etc.
2006 Nomad 1600
Can I do a quick splice into this wire ? don't want to be cutting any wires if I can help it.
Cheers
saffer is offline
post #2 of 2 (permalink) Old 03-02-2016, 11:17 AM
I would suggest running it directly to the battery through a relay. The relay will only be powered 'on' when the ignition is on. The wire I would suggest using for powering the relay would be the license plate light. That way, if something happens to the audio system all you lose is the license plate light.
You may want to consider looking at some of the fuse boxes with relays if you decide that you may want to add other things later. That way you have a one time wiring job and all subsequent electrical items can be wired to the fuse box. The other benefit of some fuse boxes is that they have a tail for a charger so you can easily hook up your battery tender without removing the seat.
Calais is offline
Some pulley math: RPM/mph of similar cruisers VulcanDan61 Vulcan 900 3 06-25-2015 12:36 PM
has ANYONE double Debaffled, or similar? CptCrusty1 Vulcan 1600 0 05-29-2013 12:47 PM
WTB Vulcan 800 drag pipes or similar ChrisM Wanted to buy or trade Items 1 02-03-2013 08:00 PM
Do I really need a PCV or similar?? Avee8tor Vulcan 1700 2 06-21-2012 10:47 AM
WTB: Mustang or Similar Seat and Sissy Bar for '07 V900 Custom NIUPonyBoy Wanted to buy or trade Items 1 08-20-2009 01:59 PM
