Problem with valve stems - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 01-28-2016, 01:25 AM Thread Starter
saffer's Avatar
Year/Make/Model: 2006 Vulcan Nomad
Displacement/CC's: 1600
Color: Black
Tried checking my tire pressure last week-as soon as I took the valve stem caps off air started releasing from the tires ( both front and rear)
Limped to the nearest gas station to put some air in. Is this a problem with the valve stems ( funny it should be both !!) or the inner valve goody. I have a inner valve removal tool-should I try removing the inner valves and replacing them ?
saffer is offline
post #2 of 7 (permalink) Old 01-28-2016, 07:56 AM
bigblockyeti's Avatar
Year/Make/Model: 2008 V2KLT
Were both valve cores tight? If you're planning on changing them out, I've found it works best to fill the tire up before changing and be quick. It beats doing it slowly with the each tire suspended off the ground.
bigblockyeti is offline
post #3 of 7 (permalink) Old 01-28-2016, 09:22 AM
Bandit101's Avatar
Year/Make/Model: 2015
Displacement/CC's: 103ci
Color: Black
Are you using dynabeads? Often they will block the stem valve from seating.
Bandit101 is offline
post #4 of 7 (permalink) Old 01-28-2016, 05:40 PM Thread Starter
saffer's Avatar
Color: Black
Dunno what the previous owner used.....how can I tell if dynabeads have been used ?
cheers
saffer is offline
post #5 of 7 (permalink) Old 01-28-2016, 05:46 PM
Bandit101's Avatar
Color: Black
If the valve is still leaking, I would completely remove it and inspect for signs of tiny glass looking beads around the seal.
post #6 of 7 (permalink) Old 01-28-2016, 05:54 PM
Both having problems at the same time seems a bit odd.
I wonder if someones having a laugh.
I'd try tightening the cores before replacing them.
2016 Indian Roadmaster
Thunder Black
post #7 of 7 (permalink) Old 01-29-2016, 01:05 PM Thread Starter
saffer's Avatar
Color: Black
Thanks replies guys- the tightening option seems like a good first step.
cheers
saffer is offline
valve stems lewisevery Vulcan 1500 0 04-28-2018 05:43 AM
Angled Valve Stems chench53 Vulcan 650 S 6 03-05-2018 11:31 AM
Access to Valve Stems Romper Vulcan 900 19 11-18-2014 01:30 PM
Anyone use longer mirror stems? OhioVoyager Vulcan 1700 17 05-08-2012 07:33 AM
Tubes what valve stems? erh Wheels and Tires 0 03-13-2011 09:31 AM
