Cam chain tensioner extension install - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 12-15-2015, 10:14 AM Thread Starter
Year/Make/Model: 2006 Nomad
Displacement/CC's: 1600
Color: black
I've watched several videos and read lots of opinions about these, it looks to be a fairly straight forward procedure...
But then I read stuff like this: Cam Chain Tensioner Extenders Installation - Vulcan Bagger Forums
and it worries me because I dont understand all of it. Like this for example:
"Don't remove a tensioner without first insuring that the related cylinder is at top dead center on the compression stroke. Otherwise, an open valve can close under the pressure of its spring, spinning the camshaft and slipping the timing. Important to note that there is absolutely nothing that prevents the chain from slipping on the gear other than gravity and friction, neither of which are guarantees in this situation."
I'm not a mechanic, I've done brakes, plugs and fluid changes on my bike, that's about the extent of it... is this something I should take on, or should I have a shop do it? If the shop does it, how long can I expect to be billed for?
Thank you
eg78 is offline
post #2 of 8 (permalink) Old 12-15-2015, 10:34 AM
JD Hog's Avatar
Year/Make/Model: 2015 Vulcan Voyager
Color: Metallic Carbon Gray/Metallic Spark Black
If I were unsure of doing this procedure I would get a quote from a shop before starting. That way you can make an informed decision on whether you should try this or pay the professional and be covered if a mistake happens.
Jim Diebolt
2015 Vulcan 1700 Voyager ABS
"The Black Kaw"
JD Hog is offline
post #3 of 8 (permalink) Old 12-15-2015, 11:54 AM Thread Starter
Color: black
if it's under a cNote I'll have it done... otherwise I might try to do it myself... the ticking is pretty annoying, Im guessing once i put my dual bagger V&H pipes on I wont hear it as much though :-p
eg78 is offline
post #4 of 8 (permalink) Old 12-15-2015, 12:55 PM Thread Starter
Color: black
Funny, the dealerships I spoke with are not sure what this is... (they are Kawi dealerships). Am I crazy?
eg78 is offline
post #5 of 8 (permalink) Old 12-15-2015, 01:19 PM
Are you sure the tensioners are out of travel? There's a couple ways to check. You can visually inspect the tensioner travel per Gadget's page, or even easier inspect the spark plug well sleeves for wear marks, also on Gadget's page.
Harley165 - Vulcan500 - Triumph865 - Vulcan900 - Vulcan1500 - All sold but I miss em!
redfish is offline
post #6 of 8 (permalink) Old 12-15-2015, 01:23 PM Thread Starter
Color: black
No I am not, I will verify this. Thanks!
eg78 is offline
post #7 of 8 (permalink) Old 12-15-2015, 01:38 PM
Check the spark plug wells (tunnels) for wear: Spark Plug Tunnel/and Tool - Vulcan Bagger Forums
Check the tensioner travel: Cam Chain Tensioner Extenders
redfish is offline
post #8 of 8 (permalink) Old 12-15-2015, 01:52 PM Thread Starter
Color: black
I just read this whole thing, man doesnt seem too complicated... I'm gonna check myself and do the install myself if necessary.
Thanks, that's a super write-up!
eg78 is offline
cam chain tensioner stevieb Engine Work 1 09-24-2011 12:54 PM
extended cam chain tensioner vanislenomad Vulcan 1600 10 06-05-2011 08:38 PM
Automatic-Cam-Chain-Tensioner (ACCT) on Front Cylinder Spock1 Vulcan 1500 2 09-09-2010 11:20 PM
New cam chain tensioner extenders PatC Vulcan 1500 2 08-08-2010 12:25 AM
'91 Vulcan, manual cam chain tensioner? mybrainisawaffle Vulcan 500 8 08-02-2010 02:33 AM
