Motor oil leak under left side case covee - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 13 (permalink) Old 12-07-2015, 02:06 PM Thread Starter
iamarchie's Avatar
Year/Make/Model: 2007 Kawasaki Vulcan 1600
Displacement/CC's: 1552 CC's
Color: Black
Motor oil leak under left side case cover
Hello, my 1600 has developed an oil leak. It appears to be coming from under or behind the left side case cover. I haven't had a chance to look at it as I just noticed it moments ago. Has anyone seen this before? Not going to be able to touch it for
two weeks but curiosity is killing me.
iamarchie is offline
post #2 of 13 (permalink) Old 12-11-2015, 01:37 PM
Sounds like the clutch push rod seal behind the cover. They can leak a little if they get worn. Easy fix by replacing with a new one. Just takes a little time.
I had that issue with my 1600 a few years ago.
DesertDog288 is offline
post #3 of 13 (permalink) Old 12-14-2015, 08:39 PM Thread Starter
iamarchie's Avatar
Color: Black
Copy DesertDog288, that's sounds simple enough. I couldn't visualize what's behind the cover. I've only had that cover off once to flush the clutch fluid.
Thanks for the heads up.
Bret
post #4 of 13 (permalink) Old 12-20-2015, 05:34 PM
sunnybob's Avatar
get under and check exactly where it is coming from. If it is hydraulic fluid, then its the clutch slave cylinder.
If its engine oil, there is a weep hole in the middle of the crank case that warns you the oil seal behind the water pump is defective.
Sunny Bob
sunnybob is offline
post #5 of 13 (permalink) Old 12-27-2015, 04:59 PM Thread Starter
iamarchie's Avatar
Color: Black
Copy, sunnybob thanks for the heads up. I'm quite sure it is motor oil. I'll be pulling the cover off in the next couple of days. Have you replaced that oil seal before?
Bret
post #6 of 13 (permalink) Old 12-28-2015, 02:29 AM
sunnybob's Avatar
clean the bottom of the engine cases, dust baby powder all over them, and go for a half hour ride.
The baby powder will show you exactly where the oil is coming from.
If it is the small hole (about 3/8" diameter) just to the right of crankcase centre, then its a serious issue.
I have never had to replace that seal. The factory book says the engine has to be totally stripped to replace it from the inside. But I have heard of good results by someone's kit that doesn't need so much work.
Its been a while now, but I think the adaptor seal is made by chuckster. surf for that.
If its from somewhere else, then still the baby powder will still show you the way, and hopefully it will just be a gasket.
Sunny Bob
sunnybob is offline
post #7 of 13 (permalink) Old 01-04-2016, 08:50 AM
Rustyfender's Avatar
Had this happen some years ago and just put silicone around the seal, make sure you don't get any on the rod. Clean the area well I used brake cleaner, drain some oil so it is not going to mess the area up. Push it back into the case making damn sure you don't go too far. Let it cure and your done. Top oil up.
There is better instructions on the Vulcan Baggers forums site: Vulcan Bagger Forums - Powered by vBulletin and Gadgets Vulcan fix it page might cover it Vulcan Gadgets Fixit Page For Kawasaki Nomad & Classic Modification Maintenance & Repair
Rustyfender is offline
post #8 of 13 (permalink) Old 01-04-2016, 11:07 AM
sunnybob's Avatar
Rusty, your fix is for the clutch slave cylinder seal. It looks like iamarchie has a an oil leak on the water pump shaft.
I expect he'll let us know when he's found it.
Sunny Bob
sunnybob is offline
post #9 of 13 (permalink) Old 01-04-2016, 08:19 PM Thread Starter
iamarchie's Avatar
Color: Black
It's cold in the garage!
I haven't pulled the cover yet its cold out there, but im ready to crank up the propane heater and the stereo in the garage. I am greatful for the insight, thank you. I'll post what I find.
Also im using the Barnett heavy duty clutch spring. Any thoughts about the Mean Streak vs Barnett's.
I'm going to throw in judges Washers.
Bret
post #10 of 13 (permalink) Old 01-05-2016, 12:59 AM
sunnybob's Avatar
I never changed a clutch on any of my vulcans, but from what I've read, the barnet develops left hand muscle strength
Sunny Bob
sunnybob is offline
Oil/clutch fluid leak left side Cobra193 Vulcan 1600 3 03-04-2018 08:30 PM
oil leak on the left side near the shifter/ chrome cover gkalyanapu Vulcan 1700 15 03-05-2017 05:22 PM
v900 engine oil leak under left cover motorcycle Vulcan 900 10 08-24-2015 08:18 AM
Left side crankcase oil leak sjvalleydave Vulcan 1500 3 02-07-2014 12:39 PM
Left side oil leak timallix Vulcan 1500 6 09-26-2010 09:09 PM
