1500 vs 1600 engine - Kawasaki Vulcan Forum : Vulcan Forums
 6Likes
post #1 of 21 (permalink) Old 11-22-2015, 08:10 AM Thread Starter
Year/Make/Model: 2006 Nomad
Displacement/CC's: 1600
Color: black
1500 vs 1600 engine
Are they interchangeable ? If I buy an old 1500 can in use parts inside to rebuild my 1600?
eg78 is offline
post #2 of 21 (permalink) Old 11-22-2015, 08:13 AM
Color: Orange SE
No. It's likely a small handful of components are shared but it's an entirely different platform. Not a direct replacement nor could you salvage a 15 to rebuild a 16 or vice versa.
Romans5.8 is offline
post #3 of 21 (permalink) Old 11-22-2015, 08:14 AM Thread Starter
Color: black
Thank you for the info !
eg78 is offline
post #4 of 21 (permalink) Old 11-22-2015, 08:16 AM
Color: Orange SE
As cheap as these are; you'd probably end up spending more money rebuilding your 1600 then you would buying another 1600! Or even a 1700!
post #5 of 21 (permalink) Old 11-22-2015, 08:19 AM Thread Starter
Color: black
I'd love to find a salvaged 1600 engine with low km cheap to direct swap...
eg78 is offline
post #6 of 21 (permalink) Old 11-22-2015, 08:24 AM
Color: Orange SE
What issues are you having? Just curious.
Good luck! I'm sure you could find a salvage 1600 somewhere.
post #7 of 21 (permalink) Old 11-22-2015, 08:25 AM Thread Starter
Color: black
My compression reading is 115 and 135, apparently that's not great, I can ride it a while but it will inevitably die.... according to the shop mechanic anyways...
There ar 115000 km on it.
eg78 is offline
post #8 of 21 (permalink) Old 11-22-2015, 09:59 AM
Again, like I said, do fret over those compression readings unless you are having a specific problem, such as excessive oil consumption, etc.
Another used engine may be no better, and to overhaul one of these "correctly" can put costs out of reach in a hurry!
The mechanic is putting worry thoughts in your head probably needlessly.
eg78 and johnborsellino like this.
sfair is offline
post #9 of 21 (permalink) Old 11-22-2015, 10:18 AM
Bandit101's Avatar
Year/Make/Model: 2015
Displacement/CC's: 103ci
Color: Black
I respectfully disagree with your previous information.
First I would suggest you find another shop to do your compression test as those numbers are very good.
These engine have an automatic compression release (to aid in starting), that does not release until approx. 800rpm.
It is a centrifugal device that is installed on the end of each camshaft, slightly holding the exhaust valve open till
engine starts. Consequently, this also reduces compression readings.
The 15 & 1600, engines share almost all the same parts including the case. Transmissions are identical
including the gear ratios. When changing components such as crankshaft, the entire assembly must be
swapped. (rods, pistons, cylinder. 15 &16s even share the same crank counter balance weights. Heads,
clutch, coolant, and FI systems are also interchangeable.
A complete 1500 E series up (fi injected) engine is a direct replace for a 1600.
sfair, eg78 and johnborsellino like this.
Bandit101 is online now
post #10 of 21 (permalink) Old 11-22-2015, 10:25 AM Thread Starter
Color: black
Wow that's the most promising thing I've heard so far, I will definitely get another opinion, thank you !!
eg78 is offline
Radial vs. Bias, Metzeler 880 vs. 888 vs MC Commander II TrentonC Vulcan 2000 36 04-12-2016 01:01 PM
1500 vs 1600 Chief Jim Vulcan 1600 5 02-01-2014 09:05 AM
1500 vs 1600 Chief Jim Vulcan 1500 2 01-31-2014 08:05 PM
mean streak 1500 vs. 1600 big difference?? chicagoster Vulcan 1600 11 09-03-2011 11:04 AM
1500 vs 1600 vs 1700 puckoach General Vulcan Talk 22 01-22-2011 07:41 PM
