Normal cylinder compression on vn1600? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 11-19-2015, 02:18 PM Thread Starter
Year/Make/Model: 2006 Nomad
Displacement/CC's: 1600
Color: black
I've found a lot of conflicting information on the net about this.
Had my 2006 VN1600 tested for cylinder compression and it came back as follows:
Front cylinder: 115psi
rear cylinder: 135psi
Some articles suggest [email protected] is normal, the shop that tested says it should be upwards of 150... I (obviously) dont know anything about this and am trying to figure out if I actually have a problem with this engine or not...
Any help is appreciated.
eg78 is offline
post #2 of 5 (permalink) Old 11-19-2015, 07:36 PM
Because of the compression release, compression test values can vary.
Unless you are experiencing a specific problem, I would not even bother with the test.
sfair is offline
post #3 of 5 (permalink) Old 11-19-2015, 07:39 PM Thread Starter
Color: black
Thanks, good to know, there is a bit of a ticking, but I wouldn't call it a knock.
eg78 is offline
post #4 of 5 (permalink) Old 11-19-2015, 09:16 PM
Ticking is probably valvetrain noise.
Could be as simple as incorrect oil viscosity to as complicated as collapsed HLA's and everything in between, including timing chain extenders.
sfair is offline
post #5 of 5 (permalink) Old 11-20-2015, 06:14 AM Thread Starter
Color: black
I'll change the oil as soon as I bring it home from the shop, I'll have another listen and do some compression tests myself. I might take a gamble and buy a vn1600 engine for sale in Calgary that apparently has 10k km in it but the bike was scrapped. Will cost me about 500$ shipped. Was thinking of a swap and comparing compression and noises and deciding which one to keep, or attempting to rebuild of one of them....
eg78 is offline
Cylinder Compression too high ? gwaihir Vulcan 1600 9 11-15-2017 12:17 AM
Front cylinder compression too high daremoe63 Vulcan 1500 4 04-16-2015 08:00 AM
Front cylinder low on compression paulcagefighter Vulcan 1500 10 06-18-2014 12:24 PM
what's the technique for getting an accurate compression reading on these engines? pugetsoundsailer Vulcan 1500 2 06-01-2009 12:31 PM
compression release? 2tonbuick General Vulcan Talk 5 05-28-2009 07:12 AM
