koso tach instalation - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 15 (permalink) Old 10-28-2015, 04:39 AM Thread Starter
Year/Make/Model: 2003
Displacement/CC's: 1600
Color: black (of coarse)
has any one tried fitting a koso tach to there 1600 ive got it to read by wrapping the sensor wire around the spark plug lead but it was so erratic it drove me crazy,ive tried connecting it to the negatives on the coils with a tach adapter with no joy and on one coil with no adapter no joy, driving me crazy,it might just end up being a good looking accessory
2003 1600 classic,power commander,hypercharger,cobra 2-1,progressive rear shocks,braided front brake lines,barnet clutch with heavy duty spring, lots a chrome.If you goin to do it ,do it to Thmax
Thmax is offline
post #2 of 15 (permalink) Old 10-28-2015, 07:16 AM
Kycruiser's Avatar
Year/Make/Model: 2008 vulcan 1500FI Classic
Displacement/CC's: 1470
Color: Red/White
Yeah I don't really need one but think i would look really cool to have one. Let us know if you get it working correctly.
Kycruiser is offline
post #3 of 15 (permalink) Old 10-28-2015, 09:30 AM
Can you post back with a link to the particular tach you have?
sfair is offline
post #4 of 15 (permalink) Old 10-28-2015, 03:36 PM Thread Starter
I see on the koso site they have an upgraded model but in ebay its the koso dl universal tach bb 552b80 22110075
Thmax is offline
post #5 of 15 (permalink) Old 10-29-2015, 09:26 AM
Could you tell me what wires you connected where and how.
sfair is offline
post #6 of 15 (permalink) Old 10-29-2015, 07:00 PM
BOTM Winner
December 2016
Luckymann77's Avatar
Location: Where the Horses Are Fast and the Grass is BLUE !!!
I went with a Bikers Choice from Powersports Superstore..
Simple hookup...
Hot, ground, dimmer, and coil...
Lights up blue, looks good and works great !!!
Hardest part was finding a bracket to mount on the handle bars cuz the white face version doesnt come with one which was a bummer...
Found it from Orange County Cycles I think...
You dont need a dual fire adaptor on a 1600...
BTW...the correct coil post to use is closest to the frame...
I used the right side coil ...
Use a 10mm wrench to remove both mounting bolts and flip the coil around for access to it...
I also made a harness with male and female crimp-on connects and some heat shrink tubing...
Plug and play...
Back to football !!!
Luckymann77
I love you more today than I did yesterday...
Yesterday you really PISSED ME OFF !!!
Long Time Rider...
First Time Vulcan Owner...
2005 Vulcan 1600 Classic
Majestic Metallic Red
Bagged up !!!
Chromed and Studded out !!!
Big 3
Cobra Dragsters
Cadmann
Wiseco/Doebeck EJK
Luckymann77 is offline
post #7 of 15 (permalink) Old 10-29-2015, 07:34 PM Thread Starter
Ive sent an email to koso they said the erratic display is usually a bad earth so I have a direct earth to the battery as well as one to the frame and the pick up I have wrapped the sensor wire around the spark plug leads off the no.1 coil at idle it will bounce around from 8 to 14 then down to 6 and holding revs it will go from say 20 to 28 then back down to 18 then 23 -28 -20 etc ,I have tried connecting to positive and negative coils with no luck (not at the same time ;-) )
Name:	handle bars 003.jpg
ID:	141777   Click image for larger version
Name:	handle bars 001.jpg
ID:	141785   Click image for larger version
Name:	handle bars 004.jpg
Thmax is offline
post #8 of 15 (permalink) Old 10-29-2015, 07:40 PM Thread Starter
Ive sent an email to koso they said the erratic display is usually a bad earth so I have a direct earth to the battery as well as one to the frame and the pick up I have wrapped the sensor wire around the spark plug leads off the no.1 coil at idle it will bounce around from 8 to 14 then down to 6 and holding revs it will go from say 20 to 28 then back down to 18 then 23 -28 -20 etc ,I have tried connecting to positive and negative coils with no luck (not at the same time ;-) )Ive also made some new handle bars to allow for my 6 ft 4inch frame
Thmax is offline
post #9 of 15 (permalink) Old 10-29-2015, 07:43 PM Thread Starter
was that the plug on the out side of the coil? positive I think
Thmax is offline
post #10 of 15 (permalink) Old 10-29-2015, 08:18 PM
BOTM Winner
December 2016
Nope...
The coil on the right side of your bike...
The coil terminal on the left of that coil...
Its the terminal up under the gas tank closest to the frame's backbone...
You have to remove the coil to get access to the terminal...
Remove both the 10mm mounting nuts and pull the coil off the studs to turn the coil around...
Also, all power and ground wiring is available in your headlight bucket...
Hope you get it working !!!
Good Luck !!!
Long Time Rider...
Bagged up !!!
Big 3
Cobra Dragsters
Cadmann
Wiseco/Doebeck EJK
help with Koso tach wiring _Ripper Vulcan 900 29 10-11-2015 10:30 PM
Yamaha TRUNK RACK Instalation 1oldtimer Vulcan 1700 9 08-29-2012 03:10 PM
led signal instalation problem madmaths Vulcan 900 4 08-12-2012 10:25 AM
Cobra tri-ovals instalation mwt ski Vulcan 1700 5 04-11-2011 09:43 AM
