2008 Nomad 1600 oil leak - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 09-28-2015, 01:40 PM Thread Starter
Hi All.. Thanks in advance for all your help. My Buddy has an 08 Vulcan 1600 Nomad.. it has an oil leak coming from what looks like is probably the oil pump but I cant confirm its the oil pump. Can anyone tell me what this is? Left side crankcase cover has been removed in the pic and the part is circled. The oil leak is coming from the bottom of the 3 mounting bolts. Before we just yank it off we want to know what we are removing. Any idea's or suggestions?
Thanks!
Bill
2008 Kawasaki Vulcan 1600 Nomad
mrgomerpyle is offline
post #2 of 5 (permalink) Old 09-28-2015, 05:01 PM Thread Starter
Looks like this is the clutch slave cylinder. Going to tear it apart and see what all need to be replaced. Once I figured out what tha part was I googled and found a nice write up with pictures on how to do this. Dont want to put up a link that may go dead so I will allow you to just google it also.
post #3 of 5 (permalink) Old 04-27-2016, 07:01 AM
lowfly's Avatar
Year/Make/Model: 2010 Vulcan Voyager
Cheers for that, just found it, and yes mine has just started to mark it's spot as well.
Thank you.
lowfly is offline
post #4 of 5 (permalink) Old 04-27-2016, 07:54 AM
Dean's Avatar
Year/Make/Model: 2006 Kawasaki Vulcan
Displacement/CC's: 1500FI
Color: Ebony Black/Galaxy Silver
My 1500 has been doing that for a while, not much a few drips her and there. I have replaced the clutch hose, the spacer or "gasket" behind the clutch slave cylinder as well as the banjo bolt and washers. I have also replaced the 2 O rings on the black cover to the left. So far there is still a slight drip there......
One time it was brake fluid from the clutch and other sit has been dark or motor oil, but the oil level never seems to drop either....
06 1500 Classic FI (Anniversary Edition)
Reward the truth, punish the liars...Ted Nugent
Dean is offline
post #5 of 5 (permalink) Old 05-01-2016, 12:28 AM
lowfly's Avatar
I've ordered the seal and pushrod that are behind the clutch slave cylinder.
lowfly is offline
Oil leak + Exhaust leak + Windscreen Positioning _Kodiak_ Vulcan 1500 20 06-01-2018 10:56 PM
Oil Question 1600 Nomad 2008 kinos Vulcan 1600 5 06-08-2015 07:44 PM
Nomad 1600 oil leak Keeper Engine Work 5 10-10-2011 08:51 AM
2008 Nomad 1600 Synthetic Oil or Not? JBSpook2010 Vulcan 1600 17 11-17-2010 07:05 AM
VN 900 2008 VS Vulvan Nomad 1600 2008 Guiri2009 Vulcan 1600 14 05-31-2009 05:45 AM
