Idle and backfire problem - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 09-01-2015, 04:45 PM Thread Starter
I went ahead and just completed having a 2007 1600 Meanstreak engine installed into my 2002 Meannie. The engine fit, but having some trouble with the idle and some back-firing. Can't seem to get the idle to settle down to about 800 where it should be. It either races at 1400 or drops to 200 rpm and stalls. Seems to be no middle ground. Also backfiring when shifting under acceleration. Wondering if installing a Power Commander will help solve this problem of there is something I'm missing here.
Any advice?
Lovjoy is offline
post #2 of 2 (permalink) Old 09-02-2015, 05:34 AM
I think you have a vacuum leak somewhere. Idle should be in the 950-1050 range, 800 is to low.
07vulc is offline
Idle idle idle Derek Vulcan 800 9 04-23-2017 08:49 AM
Problem getting worse, backfire loss of power. Tangleberry Vulcan 1500 5 03-21-2016 12:25 PM
Exhaust backfire style loud pop and Idle adjustment. ta-kid Vulcan 1700 9 05-31-2013 10:45 PM
'help with resetting fuel jets, idle mixture screws and main idle screw' Riz Vulcan 500 2 01-28-2013 09:07 PM
help with resetting fuel jets, idle mixture screws and main idle screw Riz New Member Introductions 3 01-21-2013 08:19 PM
