Rigid strut/shock - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 1 Post By chanoc1077
  • 1 Post By DANAD
post #1 of 7 (permalink) Old 04-17-2019, 10:30 AM Thread Starter
kikwaam's Avatar
Year/Make/Model: 2007 Kawasaki Vulcan 2000 Classic LT
Displacement/CC's: 2053cc
Color: Black/Red
Rigid strut/shock
Has anyone heard of a rigid strut for the v2k?
kikwaam is offline
post #2 of 7 (permalink) Old 04-18-2019, 12:59 PM
whoaru99's Avatar
Rigid, as in like no spring/shock, i.e. hardtail?
Or, Rigid as in brand?
I've heard of neither. But, FWIW, put on mine a Progressive shock that has the remote adjustable preload feature.
whoaru99 is offline
post #3 of 7 (permalink) Old 04-18-2019, 03:06 PM Thread Starter
kikwaam's Avatar
Color: Black/Red
Im a big boy, 300+ lbs 54 in chest and my son rides on the back.... he is about my size. I scrape the tailpipes around corners when he is with me. So I want to go hardtail.
kikwaam is offline
post #4 of 7 (permalink) Old 04-18-2019, 08:05 PM
Year/Make/Model: V2K Does it matter what year??
Displacement/CC's: A Shitload
Color: Black+Gun Metal
There are threads that talk of ways to do pre-load plus with a spacer, if you go hardtail your column will let you know in a hurry. That's a good and sure way to mess up your inner frame.
kikwaam likes this.
salu2
Chanoc
chanoc1077 is offline
post #5 of 7 (permalink) Old 04-18-2019, 08:54 PM
whoaru99's Avatar
Replace the pipes instead. Yeah, no doubt will cost a chunk more than a steel rod or some sort of spacers, but hardtail...egads man.
I had the same thing happen driving two-up with me and the SO when I'd hit the curves.
V&H Powershots have not scraped, ever, and I still have a bike I can stand to ride and walk normal after more than around the block a few times. 😉
I'm a big guy myself ~250, and my SO isn't exactly petite but not quite that big. I'd be even more concerned about frame or other things with essentially no cushion other than the rear tire.
whoaru99 is offline
post #6 of 7 (permalink) Old 04-19-2019, 02:09 PM
Also, if your son is that big, pro'bly is the time for him to get his own bike, Weight capacity on our big bikes should be around 450-500 lb (I think, I've seen the precise data somewhere when I was prep'ing for the trailer but could not find it just now). SO the first sign you might be close to weigh capacity is if you start bottoming out on the bumps from the roads, the smaller the bump you bottom out in = the closer you are to your limit. 2nd sign is scraping pipes and/or floorboards in mild(er) curves.
Preload just lets you adjust to a certain point but scraping is just a symptom, you can be stressing the frame/ tires/ brakes/ pegs/ kickstand/ etc and it all goes back to general safety, it can be dealt with being extra careful but when it starts messing with the enjoyment factor it is time to re-think.
I am also on the heavy side, trying mi hardest to stay below 250 after I was "scraping" the 300's for a while but I am lucky my wife is on the petite side, even so I make sure we do not go above the 400 lb (including the stuff on the hard-bags, tools and such) if were going for long rides or the 450 for day or weekend rides, hence the trailer.
To be able to travel 2 up the trailer was the only option I see viable weight wise, so far it has turned out a good choise.
salu2
Chanoc
post #7 of 7 (permalink) Old 04-20-2019, 10:13 AM
DANAD's Avatar
Ditto on the big part, and my wifey isn't a ballerina lol. I posted pics a long time ago about adding a spacer to increase the preload to carry about 700lbs. The hardest part is "caging" the spring to safely remove the snap ring in the original top spacer. I used several large mechanical hose clamps to gradually pull the spring tight and left it caged while I took the original spacer down to the machine shop and had them spin me up a new one that was about an inch deeper. Also, I put a darkside tire on that was a 65 series which lifted the bike another inch.
kikwaam likes this.
2004 VN2000
V&H Pipes
BAK, Mustang Seats, Scootworks Tour Trunk
HD Softail lowers, Memphis shield
Darkside Falken Zeix 205/65/16 rear, Bridgestone Excedra Max front
2008 900C as barhopper
DANAD is offline
soft to rigid hue-e Wrench Heads 0 05-30-2012 02:41 PM
2011 compatible rigid saddlebags? SlapTheCat Vulcan 900 2 09-14-2011 09:33 PM
rigid mount? Jus101979 Vulcan 500 1 07-04-2011 06:58 PM
Butt report, 745 mile trip on a rigid strutted 500 & a rigid strut 800 FRISCO67 Vulcan 500 0 07-22-2010 12:03 AM
Vulcan drifter rigid jrpitty Vulcan 800 14 06-07-2010 07:41 PM
