v2k rear axle nut - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 04-06-2019, 02:26 PM Thread Starter
kikwaam's Avatar
Year/Make/Model: 2007 Kawasaki Vulcan 2000 Classic LT
Displacement/CC's: 2053cc
Color: Black/Red
v2k rear axle nut
What size is the rear axle nut on the v2K? I cant seem to find it in the service manual. I want to pick up a socket for it.
kikwaam is offline
post #2 of 4 (permalink) Old 04-07-2019, 03:45 PM
whoaru99's Avatar
The wrench size isn't listed as service manuals typically don't give specifics for every common tool. They just expect a mechanic will figure out the necessary wrench/socket size.
That said, I think the nut is 27mm and the head is 22mm. Don't order on my word though as it is possible not all are the same.
whoaru99 is offline
post #3 of 4 (permalink) Old 04-08-2019, 04:53 PM Thread Starter
kikwaam's Avatar
Color: Black/Red
I had someone off FB tell me that the axle nut is 32mm. sounds about right.
kikwaam is offline
post #4 of 4 (permalink) Old 04-08-2019, 06:20 PM
whoaru99's Avatar
Not sure if you mean the 32mm or what I said.
Mine measured ~27mm across the nut flats and ~22mm across the head flats using a digital vernier caliper.
If you have the bike why not just double-check it yourself?
Even if you only have a Crescent-type wrench that size you can adjust it tight to the nut then measure the wrench opening to get an idea.
whoaru99 is offline
Front axle nut plug FanCee44 Vulcan 800 5 08-18-2014 11:35 PM
Help! Lost axle adjuster nut while on trip TCS7 Vulcan 900 8 06-02-2014 10:09 AM
Rear Axle Nut Size Mxboost Vulcan 500 3 05-31-2011 09:49 PM
axle nut vs torque wrench bluetick89 Vulcan 500 5 04-28-2011 08:08 AM
Quick question: Rear axle nut torque? bpneiman Vulcan 800 4 04-26-2011 03:27 PM
