plugs under seat - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 07-18-2018, 09:08 PM Thread Starter
arobsum's Avatar
Year/Make/Model: 2005 Vulcan VN2000A
Displacement/CC's: 2000
Color: metallic blue
plugs under seat
I have 2 empty elec. plugs under the seat that look like accessory ports? Not sure. Anybody know what these are?
Life. Nobody gets out alive.
arobsum is offline
post #2 of 4 (permalink) Old 07-18-2018, 09:38 PM
Yes, accessory ports. 2 more in the headlight nacelle.
Sent from my SM-G900V using Tapatalk
warrbucks is offline
post #3 of 4 (permalink) Old 07-18-2018, 11:13 PM
Year/Make/Model: 1997 Vulcan Classic & 2001 Nomad
Displacement/CC's: 1500
Color: Red, Red & Canyon Silver
Anyone know what connectors to order, ask for, to use any/all of these? Want to add light bar on separate circuit from headlight. Thinking I could use blinker wire(s)?
TrapperAH1G is offline
post #4 of 4 (permalink) Old 08-13-2018, 11:56 PM
whoaru99's Avatar
I believe those are hot all the time and fused at 15A.
0.156" bullet connectors fit in mine. First I tried the 0.180" bullets but they were too big.
I'd run a dedicated circuit for light bar draw, fused right at the battery. If you have a good switch that can work, but I used small switch assembly on mine to operate relays, then the relays do the heavy work for power to the lights.
whoaru99 is offline
Any real advantage using Iridium plugs over Reg plugs? Zzman General Vulcan Talk 11 05-17-2018 01:25 PM
A "pop!" and bluish grey smoke from under seat at startup FTLcore Vulcan 500 4 11-18-2010 03:33 PM
Wiring mess under the seat jerryneyk Vulcan 500 11 03-09-2010 01:41 PM
900 LT Accessory Connector Under the Seat billc Vulcan 900 4 12-30-2009 12:01 AM
Wiring Under The Seat! Vulcan9717 Vulcan 500 5 07-16-2009 07:56 PM
