Shift Lever Extensions - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 01-26-2018, 05:11 PM Thread Starter
dvictorh's Avatar
Year/Make/Model: 2005 Vulcan 2000
Displacement/CC's: 2053
Color: Metallic Ocean Blue
I was turned on to SoftBrake foot brake extensions and heel/toe shift lever extensions ... but of course, they are only for HDs! I did, however talk with the owner of the company, who told me he does have a brake lever extension that will fit my 2K. I'm ordering that tomorrow, but they do not have a shift lever for metrics.
Does anyone know of available replacement shift levers for a 2K or how to get a smidge more room on my floorboard with the existing levers?
Victor
No borders, just horizons...
dvictorh is offline
post #2 of 5 (permalink) Old 01-27-2018, 09:14 AM
DANAD's Avatar
Unfortunately, at least as far as finding aftermarket goodies goes, the V2K is the red-headed stepchild of the motorcycle industry... When I go to a bike show, I take a small measuring tape and a set of digital calipers with me to grab quick measurements on (usually HD) stuff I think might work on my bike. For example, I saw an Ultra with a center stand that folds up under the floorboards on each side, with the actuation lever poking out right behind the shifter side floorboard. I think I can make it work on my V2K to make the bike easier to park and lift. I have never seen an aftermarket shifter set up as an off the shelf item. I did see a V2K with a foot clutch/suicide shifter setup once and I will admit to lusting after that for a bit...
2004 VN2000
V&H Pipes
BAK, Mustang Seats, Scootworks Tour Trunk
HD Softail lowers, Memphis shield
Darkside Falken Zeix 205/65/16 rear, Bridgestone Excedra Max front
2008 900C as barhopper
DANAD is offline
post #3 of 5 (permalink) Old 01-29-2018, 08:04 AM Thread Starter
dvictorh's Avatar
Yeah, Danad, I've always had a thing for redheads!
Victor
dvictorh is offline
post #4 of 5 (permalink) Old 01-29-2018, 11:56 AM
Dvictorh,
I'm not familiar with V2K's but on my 800 I was able to make adjustments on the shifter when I added floorboards where the rod assembly tie is located in the link below. For more room I removed the lever comp. part 13236C where is attaches to a spline. Move it left or right and it will bring the shifter bar up. Hope this helps.
I'm sure someone with more experience will answer soon.
https://www.cheapcycleparts.com/oemp...e-mechanism-a2
Ron
Ron M is offline
post #5 of 5 (permalink) Old 01-30-2018, 07:51 AM Thread Starter
dvictorh's Avatar
Thanks for the tip, Ron M...much appreciated...this coming weekend I'll take a gander.
Victor
dvictorh is offline
Shift Lever Mods old Vulcan 500 4 12-13-2011 11:08 PM
Extended shift lever Furwe General Vulcan Talk 0 08-24-2011 08:47 PM
Broken shift lever bolt jmsnyder01 General Vulcan Talk 3 05-13-2011 06:23 AM
Gear shift lever - adjustable? Pete7874 Vulcan 500 31 12-31-2010 09:30 PM
Foot Too big for 900 Classic Shift Lever TIMMJAXX Vulcan 900 23 05-03-2009 09:02 PM
