If you could change how Kaw built the 2000 - Kawasaki Vulcan Forum : Vulcan Forums
 11Likes
post #1 of 13 (permalink) Old 09-16-2017, 03:54 PM Thread Starter
If you could have been the one that designed the 2000 what if any major changes would you have made differently than how the 2000 is right now.
Im sure there are more but the two biggest changes I would have done would be.
Hydraulic clutch
Shaft drive
Water Rat is offline
post #2 of 13 (permalink) Old 09-16-2017, 06:15 PM
Kept it in production
I'm gone!
crazyriderguy is offline
post #3 of 13 (permalink) Old 09-16-2017, 07:50 PM
The Heater's Avatar
Year/Make/Model: 2006 Kawasaki Vulcan 2000 LTD; 1996 Kawasaki ZX9R Ninja; 1993 Kawasaki ZR-1100 (now 1322 cc)
Displacement/CC's: 2000 cc; 900 cc; 1322 cc
I like the belt drive. Though I understand why some would want a shaft drive.
My beef is the ground clearance is heinously poor for me. I lean bikes over as far as I can on turns and on this bike I barely get it over and the boards scrape badly. So I am going to fabricate brackets to raise them up.
Other thing would probably be to offer hard bags and a legitimate rack for mounting a rear trunk.
Add cruise control. And have an on board audio system option for CB and music and intercom.
Lastly, I would ask them to use more aluminum if possible to lighten the bike, and put a better rear shock on it.
I am getting a Penske shock built for it and I am sending my forks to Lindemann Engineering in Redlands, CA to have them revalved and rebuilt to my specifications and body weight. I use primarily the front brake and I want the nose dive to be gone.
Preacher824 likes this.
The Heater is offline
post #4 of 13 (permalink) Old 09-16-2017, 08:01 PM
Hydraulic clutch
Shaft drive
Shaft drives suck! I had one fail on a VN750. IT would have cost a grand to replace. It's only a couple hundred bucks to replace a belt. Plus, the belt transfers power a heck of lot better than a drive-shaft.
I'm gone!
post #5 of 13 (permalink) Old 09-17-2017, 01:53 PM Thread Starter
I had shaft drive on a 1500 Nomad a 1500 Mean Streak and a 1500 Gold Wing and I really liked it and never had a single problem. The Gold Wing had over 100K on it when I sold it to a buddy and now it has 150k and all he or I ever did was change out the gear oil ever tire change.
I will give you the the shaft will suck up some power but the 2000 has plenty and I would give up a little oomph to get rid of the belt.
Yes a belt is cheaper to replace but what if your doing both pulleys and a belt which sooner or later will happen if you keep the bike long enough. I haven't priced pulleys but I bet the cost for the pulleys and a belt would exceeded the cost to repair a differential .
My thought anyway .
Edited to add: I changed to gear oil in the Nomad and Streak at rear tire change also.
The Nomad had 60K when I sold it and the Streak had 55k.
post #6 of 13 (permalink) Old 09-17-2017, 02:02 PM
My thought anyway .
Technically, pulley's don't wear out like sprockets for chains. My 30 year Chevy truck has the same engine pulley's on it from factory. So, yeah, no need to replace them unless something catastrophic happened. Also, belt drives don't require oiling. Maybe occasional tension adjustment. Sorry, if I bought a VN2000, I would want as much power to the rear wheel as possible w/o using a chain. Plus, belts don't make the whining noise a drive shaft does.
Silencer69 likes this.
I'm gone!
post #7 of 13 (permalink) Old 09-18-2017, 08:27 AM
1, hydraulic clutch ( tired of replacing cables and the insain maint needed to keep one in good shape due to the massive tense pull it has on the lever)
2, better rear shock ( stock this bikes set for a 180lbs rider.....ive yet to meat a 180lbs guy that is big enough to control this thing)
3, PUT A FREAKING 6 SPEED IN IT ( 5th is a dead gear with no power and the ratio for cruising around town or mountain corners makes me wanna pull my hair out. 2nd is reved too high. 3rd chugs and is reved too low. its annoying because there isnt a great sweet spot your always shifting it seems. )
other then those i can live with the rest. the ride height is a big issue i wish we had about a inch more clearance because my frame is really taking a pounding with the way roads are here. and im looking at fabbing a skid plate of sorts to try and save it from any more damage.
ramcharger is offline
post #8 of 13 (permalink) Old 09-19-2017, 02:06 PM
Silencer69's Avatar
Year/Make/Model: 2005 kawasaki Vulcan 2000 limited
Displacement/CC's: 2053
Color: Red/Black ("Black Cherry")
Everything Ramcharger said goes double for me, except ride height...
I can live with the ride height. I'd love it to be a tad lighter. I'd have liked a taller front tire (21" would be heavenly)
Silencer69 is offline
post #9 of 13 (permalink) Old 09-19-2017, 08:16 PM
smedlin's Avatar
A frame mounted fairing
Steveb2 likes this.
Yes, I'm a Chrome Whore.
2004 Vulcan 2000
smedlin is offline
post #10 of 13 (permalink) Old 09-22-2017, 10:44 AM
DANAD's Avatar
ANY fairing that doesn't make your Visa whimper....
-1 more inch between the backbone and the back spark plug.... Or a hole thru the backbone for the socket extension....
-a little more meat in the rear hub around the bearings... for when your wife ceases to be ballerina size
-rubber mounted headlight bezel on nacelle models..
2004 VN2000
V&H Pipes
BAK, Mustang Seats, Scootworks Tour Trunk
HD Softail lowers, Memphis shield
Darkside Falken Zeix 205/65/16 rear, Bridgestone Excedra Max front
2008 900C as barhopper
DANAD is offline
Things you would hange if you could. Sarek1700 Vulcan 1700 8 08-02-2018 10:46 AM
If you could go back in time would you still buy a VN900 or go to bigger bike. choco Vulcan 900 37 11-15-2014 10:07 AM
If you could pick another bike to complement your 900 timmyg123 Vulcan 900 122 12-16-2012 01:51 PM
If this works, it could be amazing for us. MN-Rider General Vulcan Talk 26 12-01-2012 10:01 AM
Oil Extractor could save us $ on oil change tedkawi Vulcan 900 18 04-26-2011 10:42 PM
