Starting Issues after a start up. - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 1 Post By vulcandoc
  • 1 Post By The Heater
post #1 of 5 (permalink) Old 07-26-2017, 12:51 PM Thread Starter
BOTM Winner
November 2016
Preacher824's Avatar
Year/Make/Model: 2008 Kawasaki VN2000
Displacement/CC's: 2053
Color: Blue/Silver
Send a message via AIM to Preacher824
Alright guys I just had to post this as it had me stumped for a little while. The other day we were getting ready for a ride and I went out and started the bike to let it run through the warm up stage. Once it cycled through the warm up stage I pulled it from the garage. Once I had cleared the wife's car I let it go dead and went to restart it. All it would do is make a clicking noise as if from the starter like the battery was weak/dead. I pushed the bike back into the garage and plugged up the trickle charger just to keep from pulling the seat, LOL. It sat there for just a minute or so and showed a charge. I hit the starter again and same clicking noise. I pushed the bike outside and tried to jump it with my vehicle. While hooked to the vehicle I tried to start the bike and it would turn over slowly for a couple of seconds and then go to clicking again. I assumed it was then either the starter or the start relay. I pulled the side cover and hit the start button and the start relay would click like crazy. I cleaned all the terminals on the relay with the same results. I removed the starter and it checked out OK. I replaced it and checked all connections. I then removed the battery and put it on a charger. It checked at 75% as soon as I hooked it to the charger. It sat on the charger until it checked out at 100%. I put the battery back on the bake with the same results of nothing but rapid clicking from the start relay. I then hooked up my Battery Load Tester, which I should have done in the first place, and under load the battery dropped to 2 volts. WOW, this shocked me as I had just charged the battery to 100%. I went online and ordered a new battery, AGM as the old one was acid, and a start relay. I put the new battery on today and bike fired right up and purred like a kitten !!! Just wanted to share my story and I hope this helps someone out if they experience the same starting issue. Preacher
Preacher824 is offline
post #2 of 5 (permalink) Old 07-26-2017, 01:04 PM
Color: Black / grey
Yes, same thing happen to me 2 weeks ago and I posted -
"How long does a battery last?"
I did hook up to my trickle charger and the battery showed full right away but wasnt.
Its a load test that will tell you the battery is bad.
Preacher824 likes this.
vulcandoc is online now
post #3 of 5 (permalink) Old 07-27-2017, 11:32 PM Thread Starter
BOTM Winner
November 2016
Color: Blue/Silver
I thought I did a pretty extensive search before I started thrashing on my bike and I am sorry I missed your post but. Next time I will look a little harder. LOL
post #4 of 5 (permalink) Old 08-03-2017, 11:53 PM
The Heater's Avatar
Year/Make/Model: 2006 Kawasaki Vulcan 2000 LTD; 1996 Kawasaki ZX9R Ninja; 1993 Kawasaki ZR-1100 (now 1322 cc)
Displacement/CC's: 2000 cc; 900 cc; 1322 cc
Get a programmable battery charger that performs at least five different levels of charging and tests the battery and gives a health report. I have been using an Optimate 6 nine step battery charger for a number of years. It performs tests when you hook up and plug it in, then tells you whether the battery will be healthy enough to charge and use, or not. Here is a link to buy one, well worth the money:
OptiMate 6 Select 9-Step 5 Amp Battery Charger for 12V Starter and Deep Cycle Batteries - Free Shipping: BatteryMart.com
I have switched to a Lithium Ion battery in my Vulcan 2000 and my older ZR1100. My ZX9R still uses an AGM battery.
First thing you do is get out your multi tester or volt ohmmeter, charge your battery with whatever charger you have until it says it is fully charged. Take it off the charger and put your leads across the terminals and take a reading. It should read, at a minimum, 12.4 volts. Assuming you got a good reading, start the bike, run it a few minutes, shut down. Test terminals of battery. If the voltage has dropped below 12 volts, you have a potential problem, and unless it reads something like 11.8 volts, you likely have a bad battery. To further test it, you can disconnect the leads from the motorcycle to the battery. Leave the battery off those leads and charge it again, and this time keep track of how long it takes to get that fully charged reading of at least 12.4 volts. If it charges up really fast from whatever low reading you had, the battery is toast for sure.
Another thing to remember is you need to run continuity tests when you have the clicking you mentioned, assuming the battery is good. First test for voltage drop across the battery terminals while starting the bike. Note the voltage drop. If it drops below 12 volts, depending on how far, the battery is your problem. If not, test between battery and the next connection, which will be the hot lead on your starter relay. Note voltage drop. Next, test across the terminals of the relay, note voltage drop. Next test from battery to hot lead from relay to the starter, then from battery to the starter. You will also test shorter routes such as the wire from the relay to the starter, etc.
Voltage drops tell you where you have a problem in your starting circuit. There are videos on Youtube demonstrating how to do these, on cars. Same for bikes. Some give specific voltage values, or you can find articles that give values, at least for cars. Again, bikes will be about the same.
Battery life? It depends on how diligent you are at maintaining a full charge. If you keep the bike on a trickle charger at least once a month for a few days each time, and the charger is a good quality charger, not one from Harbor Freight (which will French fry your battery eventually), the battery will last a minimum of 5 years. I had one last 12 years.
AGM batteries require special procedures for charging fully. You must use a charger like the Optimate I listed above to get it fully charged. Especially if you allow it to drain down too far or completely dead. Using a non-programmable, non-AGM charger will result in progressively lower and lower charge capacity of the AGM battery until it only will start the bike maybe a half dozen times before it is drained. Look for chargers, if you aren't buying the Optimate, that have special programs for AGM and gel batteries as well as flooded cell batteries.
The Heater is offline
post #5 of 5 (permalink) Old 01-11-2018, 09:31 PM Thread Starter
BOTM Winner
November 2016
Color: Blue/Silver
I put a new AGM on her and I am loving it.
Cold start issues after v&h pipes,k&n ac,and fi2000r 03lowrider Vulcan 900 9 02-28-2013 06:38 PM
Won't start after its warmed up ostbob General Vulcan Talk 14 10-10-2011 05:18 PM
Anyone have a cure for the high idle after start up warm on 09? BSE(illinois) Vulcan 900 31 04-13-2011 03:02 AM
Warm-up rpm to high after first start-up. Jeep Pirate Vulcan 900 10 10-09-2010 07:03 AM
Won't start after fill up. Please help capt_drew33 Vulcan 900 7 08-10-2009 04:15 PM
