Grounding Problem? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 21 (permalink) Old 05-18-2017, 08:06 AM Thread Starter
Year/Make/Model: 2008 Kawasaki V2K Classsic LT
Displacement/CC's: 2053
Color: Red/Silver
Question Grounding Problem?
Last night, I took my bike out. It ran poorly and I had the little red light. I got it home and could not get it restarted. The only thing that has changed since I brought it home (when it ran great for the 80 mile trip) is that I replaced the non-working stereo head unit.
It seems to me that the little red light is very generic (like a check engine light). I will disconnect the stereo tonight when I get home from work, but I'd like to hear any ideas.
Scootah_Bub is offline
post #2 of 21 (permalink) Old 05-18-2017, 05:23 PM Thread Starter
Color: Red/Silver
Continued...
I got home and jump started it. Still have the light and it is idling very low during warmup, then dies when it would normally jick back to low idle. getting an FI indicator on the dash. The bike has a Power Commander III and the previous owner said it was just dyno'd. Any ideas?
post #3 of 21 (permalink) Old 05-18-2017, 10:02 PM
BOTM Winner
October 2016
V2K_Rod's Avatar
It's the little red light the FI light? If so, you can look up the error code by following instructions on the service manual. You can obtain a copy in PDF from VN2000.com
Sent from my SAMSUNG-SGH-I537 using Tapatalk
V2K_Rod is offline
post #4 of 21 (permalink) Old 05-19-2017, 08:19 AM Thread Starter
Color: Red/Silver
V2K_Rod:
It is the FI light. It definitely feels fuel-starved. I'm going to try running a little seafoam through it and see if it helps.
post #5 of 21 (permalink) Old 05-19-2017, 09:51 AM
If you are getting an FI fault, you MUST retrieve the code and make the repair.
To not do so puts your engine at risk.
Seafoam will not help and be a waste of time and money.
sfair is offline
post #6 of 21 (permalink) Old 05-19-2017, 10:06 AM Thread Starter
Color: Red/Silver
Well, I rode it 80 miles to work today and I will have to ride it 80 miles home. Hopefully I am not doing damage.
post #7 of 21 (permalink) Old 06-03-2017, 03:41 PM Thread Starter
Color: Red/Silver
Error Code 52
So, I finally got a chance to pull the error code today and it looks like the rear ignition coil. How tough a fix is this. Looks like it might require more than a simple off the shelf multimeter.
post #8 of 21 (permalink) Old 06-03-2017, 05:07 PM
What was the code?
sfair is offline
post #9 of 21 (permalink) Old 06-03-2017, 06:02 PM Thread Starter
Color: Red/Silver
52. I looked it up. It's the rear ignition coil.
post #10 of 21 (permalink) Old 06-03-2017, 07:06 PM
Be careful, code 52 does not mean it is the coil FOR SURE.
If you have a meter, I can guide you through some tests.
Post make and model # of meter for my reference.
sfair is offline
Grounding to coil Foxman276 Vulcan 900 3 04-03-2015 07:56 PM
Grounding screw truckie453 Vulcan 900 22 04-27-2012 03:25 PM
Stalling Problem? - Maybe you have a Cosmic Ray problem in your area myVoyager1700 Vulcan 1700 1 07-30-2010 02:29 PM
Overhearing Problem? Maybe No Problem at All? QJC Oil and Lubrication 4 10-26-2009 06:38 AM
