V2K running rich - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 02-08-2017, 09:43 PM Thread Starter
thebaums5's Avatar
Year/Make/Model: 2006 Vulcan 2000 Classic LT
Displacement/CC's: 2053
Color: Burgandy
V2K running rich
I've been noticing that the ride seems to be running a bit rich lately. Noticeable only through exhaust smell however. No significant pops or snorts you might expect from a gas rich 'mix'. Is it possible that I have an exhaust leak? I have Vance & Hines pipes on it and nothing immediately visibly wrong. Any suggestions on how to lean the 'mix' (I know, talking carburetors in a fuel injected system. Forgive me, I lack the language) without losing power?
Thanks in advance!
thebaums5 is offline
post #2 of 2 (permalink) Old 02-08-2017, 09:49 PM
BOTM Winner
October 2016
V2K_Rod's Avatar
The front jug exhaust is a tough one to get right, I'd start there. New rings might be in order. Add some high temp gasket silicone and tighten. There is an idle adjustment screw behind the air filter housing, in case you might be idling too high. Lastly, check your spark plugs. The rear plug is easier to get to if you lift the rear of the fuel tank with a 2x4, there is one bolt that holds it in place where the tank meets the seat. If you are running a fuel manager make sure your settings or mapping is up to par. Best of luck.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
V2K_Rod is offline
running rich? otter Vulcan 900 7 05-12-2011 10:21 AM
New 97 VN1500 running REALLY RICH at idle??? coletrain777 Vulcan 1500 18 04-11-2011 06:11 PM
Running to rich? RockinRobin Vulcan 500 13 05-19-2010 02:33 PM
Running rich meanstreak777 Engine Work 2 04-16-2010 09:03 PM
Running rich, is it a problem? Kgreen Vulcan 900 0 07-02-2009 08:46 PM
