Rear shock replacement - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By DANAD
post #1 of 4 (permalink) Old 01-26-2017, 10:23 PM Thread Starter
bigsexxxy40's Avatar
Need to replace rear shock, can you use any 465 series shock are I there a specific one you have to get? I'm a bigger guy so I need a heavy duty shock, any suggestions on where t get a good without breaking the bank
bigsexxxy40 is offline
post #2 of 4 (permalink) Old 01-27-2017, 10:33 AM
smedlin's Avatar
You have to order one made for this bike.
Look around, I've seen it with a huge price difference between different places.
Yes, I'm a Chrome Whore.
2004 Vulcan 2000
smedlin is offline
post #3 of 4 (permalink) Old 01-28-2017, 06:15 PM
DANAD's Avatar
If you have access to a machinist...... I did a suspension upgrade on my OEM shock by increasing the preload by adding a 1inch spacer. I am a wide load and my wife isn't a ballerina so we needed some "extra" spring. Works fine. It is a dicey and low tech alternative but it worked.
ID:	181329   Click image for larger version
ID:	181337   Click image for larger version
ID:	181345   Click image for larger version
Silencer69 likes this.
2004 VN2000
V&H Pipes
BAK, Mustang Seats, Scootworks Tour Trunk
HD Softail lowers, Memphis shield
Darkside Falken Zeix 205/65/16 rear, Bridgestone Excedra Max front
2008 900C as barhopper
DANAD is offline
post #4 of 4 (permalink) Old 02-12-2017, 03:08 PM
This is one one I have found to be the best replacement. There are others. JMO
budda109 is offline
Rear shock replacement? Help budda109 Vulcan 2000 8 10-04-2016 10:01 AM
Rear Replacement shock question CLenix88 Vulcan 1500 1 02-07-2014 08:31 AM
Rear Replacement shock question CLenix88 The Bobber, Ratbike, Chopper Connection! 1 02-04-2014 10:05 PM
rear 900 shock and 800 shock tindog Vulcan 900 4 04-02-2012 10:22 PM
