Rear shock replacement? Help - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
  • 1 Post By V2K_Rod
  • 1 Post By budda109
  • 1 Post By V2K_Rod
post #1 of 9 (permalink) Old 10-01-2016, 06:06 PM Thread Starter
My wife has a 2009 2K. Nothing wrong with the rear shock. It just sucks. What are the shocks people here using? Ohlins? progressive? Model numbers would be great. Any input welcome. Thanks. PS she is a big girl!
budda109 is offline
post #2 of 9 (permalink) Old 10-01-2016, 07:49 PM
BOTM Winner
October 2016
V2K_Rod's Avatar
I believe the most common upgrade is to the Progressive 465, under $400 through Phatperformance.com I have also read good things about Ohlins, a bit more expensive and from what I understand a little bit of work to dial it in. Air ride is another option. Most air ride companies stopped making it for the VN2000, but Phatperformance.com still carries an AirFX option.
I had been saving up for the Progressive when I came upon a used air ride shock. Had to figure out the rest of the kit, but am very pleased with the adjustability and the look when lowered. Here is a write up on my suspension if you decide to go that route...
https://sites.google.com/site/rodsv2...hi-lo-air-ride
Sent from my SAMSUNG-SGH-I537 using Tapatalk
budda109 likes this.
V2K_Rod is offline
post #3 of 9 (permalink) Old 10-01-2016, 07:55 PM Thread Starter
Thank you. Just what I was looking for!
V2K_Rod likes this.
budda109 is offline
post #4 of 9 (permalink) Old 10-02-2016, 09:22 AM Thread Starter
Air shocks
Air looks cool. She is most concerned with the comfort and a better ride. The bumps can take out a molar or make you fly. Hows the ride on the air. A ride that goes low always gives up some form of functionality for the better look or footing for short legs. There is always a balance. But you loose a bit of the stroke. Ya I know. That's what she said!
budda109 is offline
post #5 of 9 (permalink) Old 10-02-2016, 11:18 AM
BOTM Winner
October 2016
V2K_Rod's Avatar
Only thing I have to compare it to is stock. HUGE improvement. I tend to ride aired up 1/2-3/4 of the way, depending on road conditions and only drop it all the way to park or slow rides for looks. It's nice to have that option.
V2K_Rod is offline
post #6 of 9 (permalink) Old 10-03-2016, 11:48 AM
smedlin's Avatar
I run the Progressive 465
If you look at the picture, right above the pipes, you can see the adjuster mounted.
Yes, I'm a Chrome Whore.
2004 Vulcan 2000
smedlin is offline
post #7 of 9 (permalink) Old 10-03-2016, 08:41 PM Thread Starter
Is it worth the difference in price? For the guy/s that can adjust on the fly how often do you really change the settings? Thanks
budda109 is offline
post #8 of 9 (permalink) Old 10-04-2016, 07:47 AM
BOTM Winner
October 2016
V2K_Rod's Avatar
I change the air based on the road I'm on. On long rides, it's constant between interstates, back roads, dirt and gravel.
Also makes a difference weather two up or solo.
V2K_Rod is offline
post #9 of 9 (permalink) Old 10-04-2016, 10:01 AM
smedlin's Avatar
It does help if you switch between 2 up and solo a lot.. you can change how stiff the shock is
2004 Vulcan 2000
smedlin is offline
Rear shock replacement bigsexxxy40 Vulcan 2000 3 02-12-2017 03:08 PM
Rear Replacement shock question CLenix88 Vulcan 1500 1 02-07-2014 08:31 AM
Rear Replacement shock question CLenix88 The Bobber, Ratbike, Chopper Connection! 1 02-04-2014 10:05 PM
rear 900 shock and 800 shock tindog Vulcan 900 4 04-02-2012 10:22 PM
