V2k debaffle/4way flashers - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By copperhead232
post #1 of 4 (permalink) Old 08-31-2016, 07:24 AM Thread Starter
Maybe beating a dead horse here but here goes anyway. Particulars are '07 VN2K LT, current mods are ais deleted, double darkside, force winder like intake. Have added a tail box, corbin 2 up seat, and led passing lights. P.O. had removed baffle screens and drilled 8 holes in each baffle plate. I've searched extensively and have found a sack full of info on the 900 but very little specific to the v2k. Has anyone had any experience? Did you have to add a fuel processor, that kind of thing. Second, I was wiring up 4 ways last night, wanted the switch on the left handlebar so pulled a trigger wire to my Switch location through the existing loom. I didn't think I could get 2 more wires through so I pulled the handlebars Switch apart and made my connections to the turn wires there. Put it all back together and put power to things to be sure I hadn't messed something up. The connection hadn't been made to the trigger wire yet. Tried my turns, all worked fine, flipped the little switch I had installed and 4 ways started flashing. WTH?! Anyway, they work without external power if you flip the switch and a turn, regardless of direction. Will this hurt the factory flasher? Thanks.
Sent from my SAMSUNG-SM-G890A using Tapatalk
rocnrol likes this.
copperhead232 is offline
post #2 of 4 (permalink) Old 08-31-2016, 08:40 AM
smedlin's Avatar
Out of curiosity, which 4 way is it?
Yes, I'm a Chrome Whore.
2004 Vulcan 2000
smedlin is offline
post #3 of 4 (permalink) Old 08-31-2016, 09:02 AM Thread Starter
Homegrown from gadgets page. Wiring diagram shown above. The connections to the battery and flasher Relay have not yet been made.if they are there will need to be diodes inserted into the circuit on the light side of the switch to prevent backfeed.
post #4 of 4 (permalink) Old 09-05-2016, 11:07 PM Thread Starter
Evidently was beating a dead horse. Sucker didn't even twitch.
4 Way Flashers jagered General Vulcan Talk 11 03-18-2012 01:46 PM
2001 Vulcan 1500 Classic FI Emergency Flashers oscm00 Vulcan 1500 3 07-27-2011 06:50 AM
Debaffle or not Debaffle? Binner Vulcan 800 11 08-08-2010 12:27 AM
Emergence Flashers wild goose Vulcan 500 15 07-12-2010 08:47 PM
Emergency Flashers? Jeep Pirate Vulcan 900 10 05-11-2010 05:55 PM
