Pulleys? - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
post #1 of 15 (permalink) Old 06-07-2016, 01:44 PM Thread Starter
Pulleys?
Ok, scoot is an 07 LT, pretty much Factory other than being double darksided and exhaust was ridden out by p.o. I've been kicking around doing something about the gears on it this coming winter. Question is do I go with euro, reverse th NA gears, or a third option I saw a bit ago is to simply install a scootworks overdrive rear pulley. It's -2 teeth than stock (70 vs.72). Any thoghts are appreciated and here's a pic of the pulley, unpolished or assembled. Thanks !
Sent from my SAMSUNG-SM-G890A using Tapatalk
Co0terV2K likes this.
copperhead232 is offline
post #2 of 15 (permalink) Old 06-08-2016, 08:43 AM
man. i really like that seat. you got any info on what part it is? and by double dark are you running a CT front? that looks too blocky to be a rear MC tire.
on the topic tho. i am in the same boat and im kind of leaning tword doing the pulley swap. it seems like less can go wrong and a lot less work . the thing i wonder about is the stock belt matching up and if it effects the ware of it.
ramcharger is offline
post #3 of 15 (permalink) Old 06-08-2016, 09:12 AM Thread Starter
Ram, the seat it a corbin dual touring. As for the double dark I'm running a general g-max as-03 (205/55-16)on the rear, and a shinko 230 tour master rear tire in 150/80-16 up front but it is turned backwards to correct for the rain grooves and belt orientation. Next go around on the rear I will likely go a bit taller to try to help with speedo error. Maybe a 215/60 or 65. Well see, I REALLY like this general. Truthfully can't tell it not a bike tire. As for the pulleys the easiest thing appears to be the 70 tooth rear from scootworks. Best guess I can find shows about a 3 mph gain across all rpms, and it would be so much simpler to pull the rear wheel and install it in place of the stocked. Scootworks claims stock belt will work fine. I still need more info before deciding though, because will 3mph be worth it for me?The pic of my scoot is about a week prior to darkside, but here's a couple of the rear to get you going!
Sent from my SAMSUNG-SM-T817A using Tapatalk
post #4 of 15 (permalink) Old 06-08-2016, 10:25 AM
yeah i run a alitimax 205/60 on my rear had one on it for the last 4 years. but been deciding what to do with the front. i think i might look into swapping to that corbin seat over my mustang seat i have currently there is just no padding in that thing and the rod from the removable back rest always digs into my tail bone.
but i understand what you mean whether or not it will be work the swap for the pulley. i know every one says the "gains" are great but id really like to see a few numbers behind it. like shift points for people and top end speeds after a swap to get a better idea i never have found a proper write up over this subject. ill be following this for a while to also see if any answers get throw out here.
post #5 of 15 (permalink) Old 06-08-2016, 07:45 PM
Bike Of The Fall Winner 2017
GFISH's Avatar
Year/Make/Model: 2006 Vulcan 900 Classic
Displacement/CC's: 903
Color: Silver
front pulley is bigger and back pulley is smaller. I heard some guys here say the scootworks pulley made a lot of noise.
"As long as I have the voices in my head, I'll never ride alone."
2006 Vulcan 900 classic
Mustang Day Tripper seat
Cobra Light Bar
Cobra Air Scoop
Cobra short sissy bar
Cobra Lowers
Baron's front and rear pulley
Baron's Big and Nasty pipes
Leatherlyke hard bags
Blue Superbrites LED accent lights
Chrome Woo Loo Air Horn
Avon Grips
GFISH is offline
post #6 of 15 (permalink) Old 06-09-2016, 10:48 AM
smedlin's Avatar
scootworks hasn't made that pulley in YEARS...
Yes, I'm a Chrome Whore.
2004 Vulcan 2000
smedlin is offline
post #7 of 15 (permalink) Old 06-10-2016, 06:21 AM Thread Starter
Just for info guys, spoke with a guy from scootworks a bit ago and they DO in fact still make the rear pulley but are currently out of stock until the next run. Next question is when's the next run?
post #8 of 15 (permalink) Old 06-11-2016, 08:49 AM
smedlin's Avatar
Umm... yea.. Marvin has been saying THAT for over 5 years now.
I'm not kidding either.
2004 Vulcan 2000
smedlin is offline
post #9 of 15 (permalink) Old 06-15-2016, 10:17 PM
Gee
Gee's Avatar
Year/Make/Model: 2006 Kawasaki Vulcan
Displacement/CC's: 2053
Color: Custom Black/Ghost True Fire
Been waiting for 8 months now since I ordered that 70 tooth rear pulley, I am thinking Scootworks isn't going to make it. Living with Euro gears for now. Have a 33 tooth front pulley, but my 215/60/16 GYTT rubs the splash guard, back to original front pulley.
'06 VN2000
Gee is offline
post #10 of 15 (permalink) Old 06-16-2016, 03:17 PM
Year/Make/Model: 2005 Kawasaki Vulcan 2000 x 2
Color: Bare metal & rust!
Our bikes run the same belts as HD, just a bit wider, 1/16" wider than an aftermarket HD Gates belt (got 40,000 miles on one, just over 200.00 from J&P). So it would seem a pretty easy job for someone to machine HD aftermarket pulleys to bolt up to our hub thingie. There has to be a million people making HD pulleys, and the belts come in every imaginable tooth count. I have an extra hub thingie I might donate if someone finds a manufacturer willing to do it.
Silencer69 likes this.
ThomBoz is offline
Front/Rear Overdrive Pulleys seandh07 Vulcan 900 14 03-16-2011 04:56 AM
Thanx 4 info Re: Scootworks pulleys BOBKAY Vulcan 900 8 01-23-2011 05:11 AM
Questions about Scootworks Pulleys BOBKAY Vulcan 900 12 01-18-2011 05:21 PM
Scootworks pulleys Kerry Vulcan 900 28 10-28-2010 07:07 PM
scootworks pulleys BRUM Vulcan 900 2 06-17-2010 09:15 PM
