Didn't Start/ Battery Posts Dirty - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 06-07-2016, 09:53 AM Thread Starter
Year/Make/Model: 2007 Vulcan 2000 Classic LT
Color: Red/Black
Went to start the 07 V2K yesterday and it would not crank over. Thought the battery may have been low in its charge so I took the seats off and hooked up the charger. It read that it was at 95% charge before it started the charge. The positive post had a little acid buildup on it so I cleaned it and tipped off the charge to 100%.
She then cranked over and started.
Thus is the second time I had to do this since February.
Is this a common occurrence with this model? If not, what can be done so this doesn't happen so frequently?
Indytunes is offline
post #2 of 4 (permalink) Old 06-07-2016, 09:57 AM
They have a battery protector spray that might help prevent corrosion.
diver dan is offline
post #3 of 4 (permalink) Old 06-07-2016, 10:01 AM
smedlin's Avatar
I've never had that problem.. had my V2K for 11 or 12 years now...
Yes, I'm a Chrome Whore.
2004 Vulcan 2000
smedlin is offline
post #4 of 4 (permalink) Old 06-07-2016, 12:57 PM
I recently went rough something similar. Starter would occasionally drag a bit, then turn over and fire. Started putting a battery tender on it did fine for a while, then dropped me one evening a bit over an hour from home. Mine would also show voltage as well as a high charge percentage. Took the batt, which btw still showed 12.4 volt and had it load tested, and tahdah, 0 amps. Open cell or cells in batt.
Sent from my SAMSUNG-SM-G890A using Tapatalk
copperhead232 is offline
Dirty but done! snoodlefist Vulcan 800 8 08-05-2012 07:51 PM
Dirty spokes forever? Mr Fistwister Wheels and Tires 6 07-08-2012 07:55 PM
dirty hands tang56 General Vulcan Talk 18 05-06-2012 12:32 PM
